Arthur England 5 #1 Posted April 26, 2020 I have a 520H in England, model number 73520 manufactured Feb 1994, without the swept front axle. It is fitted with 23 x 9.50 x 12 Dico tyres with the pattern that is now only available from Carlisle as the Turf Trac RS or the Duro HF293. I have not removed the tyres from the rim, they are badly cracked and keep going down and tyre sealant has not solved the problem, so I have not measured the rims from the inside. Roughly from the outside they look like about 7.5 inches but they might be only 7.0. Searching for answers some say 10.5 inch tyres are fine and some say that they pop of the bead. As carlisle are very expensive here at £93.68 I would want to be sure that they fit the rims before buying. The Duros are cheaper but I would still like to know. If they dont fit it will be down to a set of Wanda which are cheap but do not have the original pattern. Cheers Arthur Share this post Link to post Share on other sites
953 nut 64,110 #2 Posted April 26, 2020 You should be fine with 7" wide rims. Carlisle 23X10.50-12 CARLISLE ALL TRAIL $123.00 SKU: 511505 Condition: New Availability: Ships in 1-2 Business Days Shipping: Calculated at Checkout Overall Diameter: 23.1" Owerall Width: 9.9" Ply Rating: 4 ply tubeless Rim Width: 7" to 8.5" Share this post Link to post Share on other sites
Arthur England 5 #3 Posted April 27, 2020 Thank you for the reply, thats good to know. Cheers Arthur Share this post Link to post Share on other sites
