Countdown To Christmas!
Cape Codder
Wheel horse 310-8 37 inch side discharge Front pulley pair part #
Cape Codder
Hi, Yesterday the bearing or the piece that holds the 2 front pulleys together broke. I'm trying to find out the part number and where I could order a replacement. I've had no luck searching for it. I believe it's a pair and not 2 separate pulleys.
Thanks
gwest_ca
6-sided drive belt . Click on the pictures for more info
Regular 4-sided belt
Garry
Cape Codder
The pulley I'm looking for is behind the right front wheel. It is protected by a cover that has one large nut holding in place. It is not the pulley that is located on the deck. Sorry if I didn't explain it better. I believe it may be called a Mule drive. It's the attach-a-matic.
Edited by Cape Codder
modify
gwest_ca
That is considered part of the mower deck so it is in the parts list.
You could have 2 V-pulleys or 1 V-pulley and 1 flat idler pulley depending on deck model.
Keep track of the 2 spacers in there and their locations. One is longer than the other.
If you have the 6-sided belt there is a good page on how it has to be installed.
Garry
