cleat 8,133 #1 Posted April 24, 2020 I feel kind of dumb in that I am currently rebuilding a 312H with the M12 engine and the throttle and governor linkages have many holes in which to place springs and cables. If someone could take some pictures of their setup including the governor spring location and cable hookup locations that would be great. Thank you. Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted April 25, 2020 (edited) Best I can do at this late hour.If you need more I will see what i can do.This is an m10 setup.Chocke cable is clamped at lower right of the first picture.. Edited April 25, 2020 by JAinVA 1 Share this post Link to post Share on other sites
cleat 8,133 #3 Posted April 25, 2020 That will help a lot. I think the cables must hook into the upper outer holes in the levers. Thank you so much, Cleat Share this post Link to post Share on other sites
JAinVA 4,638 #4 Posted April 25, 2020 Cleat, With daylight I got a chance to look at the linkage on the m16.The choke and throttle cables are mounted to the same clamp station with the throttle cable closest to the blower housing. Share this post Link to post Share on other sites
