TimD 1 #1 Posted April 22, 2020 Hey everyone, I have an 310-8 that needs a new brake shaft seal. Anyone ever replace one? Also looking for a part number for it,not having much luck searching the webs. Thanks! Share this post Link to post Share on other sites
McGrew 461 #2 Posted April 23, 2020 Hi Tim, I just replaced the brake seal on my Raider 10. I am nor sure what transaxle your tractor uses, but the seal on mine was an SKF 7410. It is an easy job, but you need to be careful not to damage the new seal when sliding it over the shaft. Several members recommended using scotch tape to help getting the seal over the two flats on the shaft without damage. I can say it worked great for me! Danny 1 1 Share this post Link to post Share on other sites
troutbum70 858 #3 Posted April 23, 2020 Changing out the seal is the easy part, getting the brake drum can be a whole other matter. Some slide right off, and some require a lot of effort to get off. I seem to have the tougher ones. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,333 #4 Posted April 23, 2020 If you go to the Transmission section there are some threads pinned at the top of the list. There are charts there to find aftermarket seals. Garry 3 Share this post Link to post Share on other sites
TimD 1 #5 Posted April 23, 2020 Oh wow that definitely helped gwest! Thanks! Looks like skf7410 it is! 1 Share this post Link to post Share on other sites
c-series don 12,083 #6 Posted April 23, 2020 I just did one on my C-161. It was very simple, I guess I was one of the lucky ones because the drum slid right off. The seal popped out pretty easy, then I used a deep socket to tap the new seal in place. Share this post Link to post Share on other sites
Darkitec 4 #7 Posted June 22, 2021 On 4/22/2020 at 8:06 PM, McGrew said: Hi Tim, I just replaced the brake seal on my Raider 10. I am nor sure what transaxle your tractor uses, but the seal on mine was an SKF 7410. It is an easy job, but you need to be careful not to damage the new seal when sliding it over the shaft. Several members recommended using scotch tape to help getting the seal over the two flats on the shaft without damage. I can say it worked great for me! Danny Rat's nope, that's the one I bought online but it's for a 3/4" shaft, the shaft on mine is 1" Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,333 #8 Posted June 22, 2021 You must have a 3 or 4 speed transmission to have a 1" brake shaft. # 2 chart. Garry Share this post Link to post Share on other sites
