porschpow 7 #1 Posted April 22, 2020 I am looking in buying the Hydro assembly and the gauges for the 520H. They are asking 250 for everything. This a fair price? For the Hydro assembly, is it worth buying used or can you rebuild everything? I am assuming you can't buy it new. Share this post Link to post Share on other sites
Sparky-(Admin) 25,471 #2 Posted April 22, 2020 Pretty sure you can’t buy a new Eaton 1100 anymore. Can you test the used one? Or is it already removed from the tractor? Are you buying from a reputable seller such as...https://www.wheelhorseforum.com/forum/169-a-z-tractor/ ....or just some guy who ripped it out in his garage? I don’t know the going rate on a used Eaton but would rather deal with someone who would stand behind the used part they sold. Share this post Link to post Share on other sites
Turftech 82 #3 Posted April 23, 2020 Yes Eaton is still building a limited supply of new units. Can you buy one built to Wheel horse specs? Probably not. The golf course purchased one last August to replace a damaged one. Fasten your seat belts - $2,000.00! CW rotation on that one, W/H is CCW rotation. If one was desperate or cost not an object and had an old one with the right good pieces it could be done. Share this post Link to post Share on other sites
porschpow 7 #4 Posted April 23, 2020 Cheese WOW! Would a 1991 Wheel Horse Hydro assembly and gauge cluster be compatible with a 1996-1997 model (520H)?? Share this post Link to post Share on other sites
porschpow 7 #5 Posted April 24, 2020 I am thinking it is, but 91 to 97 seems like along shot Share this post Link to post Share on other sites
Sparky-(Admin) 25,471 #6 Posted April 24, 2020 I bet the hydro unit would be a straight swap. No idea on the gages. Share this post Link to post Share on other sites
