Racer 28 4 #1 Posted April 21, 2020 What is everyone using for a throttle cable on this style of throttle? Share this post Link to post Share on other sites
ebinmaine 81,138 #2 Posted April 21, 2020 If the handle and lever is still good you may be able to buy a universal replacement for less than $10 and repair what you have 2 1 Share this post Link to post Share on other sites
Copper116 63 #3 Posted May 9, 2020 Mine has "Choke" on both handles... I need to find a Handle or Handle and cable that is labeled "Throttle"... Share this post Link to post Share on other sites
ebinmaine 81,138 #4 Posted May 9, 2020 6 minutes ago, Copper116 said: Mine has "Choke" on both handles... I need to find a Handle or Handle and cable that is labeled "Throttle"... Check this post for info on knobs. Share this post Link to post Share on other sites
953 nut 70,318 #5 Posted May 9, 2020 I bought this set from Tractor supply the other day for ten or twelve bucks, cable was twice as long as I needed. You can open up the area that the shield screws into a little and screw the old one out then tighten it up after the new one is in place. This is from a 418-C but should be the same as yours. Share this post Link to post Share on other sites
