Mr Magoo 226 #1 Posted April 20, 2020 I found today that the long pivot bolt on the bottom of my starter/generator is snapped off. It looks like it should be over 8" long, 5/16"-24 thread. From what I can gather this part is no longer available. Anyone have a source on where to find one of these? Share this post Link to post Share on other sites
kasey54 305 #2 Posted April 20, 2020 A piece of threaded rod can be cut to length with nuts on each end.. ,I do think you could find a bolt that long . p erhaps from Mcmaster Car. Share this post Link to post Share on other sites
Mr Magoo 226 #3 Posted April 20, 2020 31 minutes ago, kasey54 said: A piece of threaded rod can be cut to length with nuts on each end.. ,I do think you could find a bolt that long . p erhaps from Mcmaster Car. The original was a grade 5. I did find one on McMaster Carr that is a grade 8 and 9" long. I will go with that. It needs to not be threaded accept for just the very end. I think it will work out. 3 Share this post Link to post Share on other sites
kasey54 305 #4 Posted April 20, 2020 Did you measure it? 8 inches seems long to me, but maybe. Share this post Link to post Share on other sites
ebinmaine 77,079 #5 Posted April 20, 2020 5 hours ago, Mr Magoo said: McMaster Carr That was my first thought. Also K L Jack. Or Grainger. It would be a pain to find but that would be on fleeeeBay as well. If you buy it from M-Carr look around and see what else you need. Saves freight charges. Other nuts and bolts. Brake linings. Tie rod ends. Lots of things can be had from them. 1 Share this post Link to post Share on other sites
Mr Magoo 226 #6 Posted April 22, 2020 On 4/19/2020 at 10:41 PM, kasey54 said: Did you measure it? 8 inches seems long to me, but maybe. What is left is 8" long and broken off right at the end of the generator housing. I would have been longer than 8" for the nut. Share this post Link to post Share on other sites
Mr Magoo 226 #7 Posted April 22, 2020 On 4/20/2020 at 4:23 AM, ebinmaine said: That was my first thought. Also K L Jack. Or Grainger. It would be a pain to find but that would be on fleeeeBay as well. If you buy it from M-Carr look around and see what else you need. Saves freight charges. Other nuts and bolts. Brake linings. Tie rod ends. Lots of things can be had from them. I did get the grade 8 bolt from McMaster. Motor is going to have to come out though for a rebuild. 1 Share this post Link to post Share on other sites
