cschannuth 3,821 #26 Posted April 19, 2020 41 minutes ago, KrazeyOlDave said: Yes Sir, I made 2 cardboard buckets, the second one worked. It’ll only hold about 200 lbs of dirt at best. So I’m not too awfully worried about the front BUT, it cannot hurt to make them stronger. I built mine using the PF Eng plans and they suggested making the bucket about the same size as the front tires for a good starting point. Looks like you ended up there. Your work is really looking good. 2 2 Share this post Link to post Share on other sites
ebinmaine 79,172 #27 Posted April 19, 2020 If the spindles from a B/C would work I've got some I'd sell for a song plus freight. I'm thinking you'd be fine with yours especially if you reinforced them in a similar manner to the pic Paul posted. 2 Share this post Link to post Share on other sites
KrazeyOlDave 860 #28 Posted April 20, 2020 I really appreciate y’all with the kind words and knowledgeable input. I do enjoy building stuff like this, plus it’s cheaper than 12k for a new tractor 😂 The intended purpose of this build is to fill in holes that my Beagles dig and to keep our pitbike track groomed. 2 1 1 2 Share this post Link to post Share on other sites
Lee1977 7,643 #29 Posted April 20, 2020 I reinforced my 312 spindles. 1 9 Share this post Link to post Share on other sites
KrazeyOlDave 860 #30 Posted April 20, 2020 Just now, Lee1977 said: I reinforced my 312 spindles. That’s perfect, then I could run a small plastic fender on the fronts. 3 Share this post Link to post Share on other sites
Pullstart 70,110 #31 Posted April 21, 2020 On 4/20/2020 at 5:48 AM, KrazeyOlDave said: I really appreciate y’all with the kind words and knowledgeable input. I do enjoy building stuff like this, plus it’s cheaper than 12k for a new tractor 😂 The intended purpose of this build is to fill in holes that my Beagles dig and to keep our pitbike track groomed. It’ll do a fine job for both those chores! 2 Share this post Link to post Share on other sites
KrazeyOlDave 860 #32 Posted April 21, 2020 You can barely see it but the cylinder is in place. I have the tractor lifted off the ground by 1”, so that I have a small amount of down pressure available. My arm gussets are a bit over kill but I did it so IF ever needed, I can put longer cylinders on it. Probably a waste of time but it’s there. 4 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #33 Posted April 22, 2020 I don‘t think they are overkill, they will last longer as you imagine. Nice design, the only thing you maybe will be missing sometimes is the liftarm lenght. When i built my first FEL, i just want to play with Hydraulics, because i don‘t wanna lift heavyer things myself furthermore. As i get older and as result of my Lifestyle until now, i feel things gettingbharder each year. So actual i use my FEL‘s what they built for, i don‘t lift myself heavier things. At the market when kati purchased planting Soil, they lift it in with a forklift, here i put it out with the FEL. Why carry heavier things with hands, if i had Hydraulic force available? Save your Back! So i learned about my doings, 2 meter’s lift height is a real good Value for universal purposes. 3 1 Share this post Link to post Share on other sites
Pullstart 70,110 #34 Posted April 22, 2020 That looks good! My ARK 500 doesn’t have a ton of down travel either, until I tip the bucket. It has been helpful to scrape some extra crushed blacktop from the side drive to fill holes in the main drive... along with digging myself backwards out of a sticky situation! 1 1 1 Share this post Link to post Share on other sites
tom2p 2,394 #35 Posted April 22, 2020 severe case of vapor lock lol 1 1 Share this post Link to post Share on other sites
KrazeyOlDave 860 #36 Posted April 24, 2020 Still waiting on my front cylinder and filter kit. Share this post Link to post Share on other sites
Pullstart 70,110 #37 Posted April 24, 2020 Have you called Lowell or Joette? They should be able to update you on your status... Share this post Link to post Share on other sites
KrazeyOlDave 860 #38 Posted April 24, 2020 4 hours ago, pullstart said: Have you called Lowell or Joette? They should be able to update you on your status... I just ordered it but yes, I talked to him on the phone. 👍👍 2 Share this post Link to post Share on other sites
KrazeyOlDave 860 #39 Posted May 1, 2020 Received my hitch today, nice product!!! You guys gave me some great advice thus far so I figured I’d through this up as to how I’m going to tie in my belly arm supports. The forward arms I plan to weld solid, while using grade 5 bolts at the rear end. Pretty straight forward really, thoughts? 2 Share this post Link to post Share on other sites
lynnmor 8,850 #40 Posted May 1, 2020 47 minutes ago, KrazeyOlDave said: Received my hitch today, nice product!!! You guys gave me some great advice thus far so I figured I’d through this up as to how I’m going to tie in my belly arm supports. The forward arms I plan to weld solid, while using grade 5 bolts at the rear end. Pretty straight forward really, thoughts? If you need special bolts, here is a chart. 2 2 Share this post Link to post Share on other sites
KrazeyOlDave 860 #41 Posted May 2, 2020 13 hours ago, lynnmor said: If you need special bolts, here is a chart. Yep, I definitely worded that wrong. Offset bolt holes, loved the chart you posted tho 😂 2 Share this post Link to post Share on other sites
ebinmaine 79,172 #42 Posted May 2, 2020 13 hours ago, lynnmor said: special bolts I've seen that in the past. It's the most fun when a ummm... "Non-mechanical" person doesn't understand that it's funny................... 1 Share this post Link to post Share on other sites
Pullstart 70,110 #43 Posted May 2, 2020 Dave, if you have enough tubing, it would be advisable to run forward past the loader mount and tie it all in with the front attachamatic. It’ll take the shear weight off the center of the tractor and help distribute it to the entire rig. 1 Share this post Link to post Share on other sites
Pullstart 70,110 #44 Posted May 2, 2020 16 hours ago, lynnmor said: If you need special bolts, here is a chart. I’ve never seen that before, but I might have to print it and hang it next to the dril index and tap chart! Those might come in handy! 2 Share this post Link to post Share on other sites
KrazeyOlDave 860 #45 Posted May 2, 2020 1 hour ago, pullstart said: Dave, if you have enough tubing, it would be advisable to run forward past the loader mount and tie it all in with the front attachamatic. It’ll take the shear weight off the center of the tractor and help distribute it to the entire rig. Not a bad idea, honestly, I think I’m reaching the breaking point of this particular tractor. The positive thing is I can retro fit it to a larger model. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,172 #46 Posted May 2, 2020 4 hours ago, KrazeyOlDave said: breaking point of this particular tractor Curious to know what you mean by that? 1 Share this post Link to post Share on other sites
Lee1977 7,643 #47 Posted May 3, 2020 10 hours ago, KrazeyOlDave said: Not a bad idea, honestly, I think I’m reaching the breaking point of this particular tractor. The positive thing is I can retro fit it to a larger model. The Wheel Horse models are about the same C-series, 300, 400 and 500 the main difference is engine size and 8 speed or hydro. There are some that are heaver with taller rear wheels and hydro transmission. The D-series, GT-14, 953, 1054. C-195. Share this post Link to post Share on other sites
Zeek 2,299 #48 Posted May 3, 2020 On 4/19/2020 at 2:06 PM, pfrederi said: One more suggestion . You seem to have the 310s original 6" wheels and spindles. I would look for 8 " wheel spindles. The are less likely to bend. Note the difference in length unsupported (Blue 6" yellow 8"). If you could source a pair of the reinforced spindles (in the back) that would be better. You are going to be putting a lot of weight on the front wheels and if you are driving over any roughness at all, a lot of stress. if you plan on putting anything heavy in the bucket. With the nice heavy duty fabrication you are doing, that alone adds a lot of weight the stock wan't designed for. 1 1 Share this post Link to post Share on other sites
KrazeyOlDave 860 #49 Posted May 4, 2020 On 5/2/2020 at 3:38 PM, ebinmaine said: Curious to know what you mean by that? Meaning exceeding the tractors structural strength. Share this post Link to post Share on other sites
ebinmaine 79,172 #50 Posted May 4, 2020 5 minutes ago, KrazeyOlDave said: Meaning exceeding the tractors structural strength. Like Lee says above, your structure is similar across all of the standard size models. Given proper bracing and connections you should be in great shape with a 310 as a front-end loader. 1 Share this post Link to post Share on other sites
