Similar Content-
			 By Dakota By Dakota
 I have the opertunity to buy either a model 607 or a 656. Each of them are $300. First of all is this a good price for either of them? The 656 comes with a deck and the 607 is just the tractor its self. Both are in good shape and both run good (so I’ve been told, don’t know for a fact) Second which one is better for farm use/plowing snow? Farm work would just consist of pulling around a yard cart with horse manure. I haven’t seen much about these models so that’s why I’m asking.
			 By powderfinger By powderfinger
 hello!!!! new here. looking at an 857. will it plow w/ a brinly easily? for purposes of pulling a firewood cart,etc, whats the top speed? whats is a fair price for one in good condition...... thanks
			By charging10
 Just wanted to show my garden! Potatoes, tomatoes and onions really took off!
 Spring time prep included cow manure, a little pot ash and 6-24-24 fertilizer.
			 By IthacaJeff By IthacaJeff
 Hi WH'ers;
 This may not belong in this section, but here goes. I've got tons of road gravel sitting on the bank of my roadside ditch due to snow plows. More than you can imagine, because last fall the town spread gravel (regular crushed limestone) on my road. The problem is, my road is asphalt (actually, tar and chip), but in such bad shape it was repaired with gravel. Of course, the gravel never packed down over the asphalt that was still intact, enabling the first plow pass to entirely push the gravel onto the bank of the roadside ditch.
 The ditch is too steep to drive my tractor, so I cannot scrape it out with the dozer blade on my 310-8 (did this on some parts not so steep). Nearly 300 feet of the ditch and lots of rock, so too much to rake by hand. Any ideas?
			By WildHorses
 I see youtube videos of smaller garden tractors tossing around the 36" Brinly-Hardy disc harrow style discs but has anyone used anything bigger? It may be a stupid question or bad thing to do but I'm just curious. I'm thinking a 520 could theoretically be made to run a hydraulic line set out the back to lift and lower a larger disc. I don't see any reason why with some wheel weights and Ag tires it wouldn't be able to pull a larger disc.
 I'm not thinking anything huge but maybe a small double gang disc, something in the 4-5' range after taking the outer plates off of a 6' unit?
