"D"- Man 827 #51 Posted May 3, 2020 Center and second outer pulley installed. Share this post Link to post Share on other sites
"D"- Man 827 #53 Posted May 3, 2020 Front rollers, springs and roller shafts w/ hardware. Share this post Link to post Share on other sites
"D"- Man 827 #54 Posted May 5, 2020 Have some decals ordered from a redqsuare vender, Terry Dennis @ Redo Your Horse. 1 Share this post Link to post Share on other sites
"D"- Man 827 #55 Posted May 7, 2020 I failed to do a step-by-step on the spindle assembly becauseI was waiting until I received the N.O.S. spindles in the post. This is all N.O.S except the housing. All parts laid out in order of assembly sequence. Share this post Link to post Share on other sites
"D"- Man 827 #56 Posted May 7, 2020 (edited) Lower bearing in housing. {Image is upside-down.} Edited May 7, 2020 by "D"- Man Share this post Link to post Share on other sites
"D"- Man 827 #57 Posted May 7, 2020 (edited) Internal snap ring Edited May 7, 2020 by "D"- Man Share this post Link to post Share on other sites
"D"- Man 827 #60 Posted May 7, 2020 (edited) Spindle shaft with Zerk fitting and cup Edited May 7, 2020 by "D"- Man Share this post Link to post Share on other sites
"D"- Man 827 #61 Posted May 7, 2020 Blade spacer (external) Share this post Link to post Share on other sites
"D"- Man 827 #62 Posted May 7, 2020 Shaft assembly in housing Share this post Link to post Share on other sites
"D"- Man 827 #63 Posted May 7, 2020 Above blade washer (thin) Share this post Link to post Share on other sites
"D"- Man 827 #64 Posted May 7, 2020 Blade (High lift) Share this post Link to post Share on other sites
"D"- Man 827 #65 Posted May 7, 2020 Under blade washer (thick) Share this post Link to post Share on other sites
"D"- Man 827 #67 Posted May 7, 2020 Shaft/blade assembly in housing with "O" ring seal Share this post Link to post Share on other sites
"D"- Man 827 #68 Posted May 7, 2020 Assembled to the mower deck Share this post Link to post Share on other sites
"D"- Man 827 #70 Posted May 7, 2020 Same procedure for the other pulleys 2 Share this post Link to post Share on other sites
peter lena 10,103 #71 Posted May 7, 2020 great job on that d man ! , i have added an extra idler pulley on the long unsupported stretch on the spindle belt , simply drilling a hole to bolt the pulley to . not much pressure on the belt , just enough to take out the belt " bounce " , a before and after run ,verify its belt drive improvement. pulley is available at T/S for about 8 $ . thought with the extensive detail that you were doing , i would only offer this as a suggestion / improvement . pete 1 Share this post Link to post Share on other sites
"D"- Man 827 #72 Posted May 7, 2020 2 hours ago, peter lena said: great job on that d man ! , i have added an extra idler pulley on the long unsupported stretch on the spindle belt , simply drilling a hole to bolt the pulley to . not much pressure on the belt , just enough to take out the belt " bounce " , a before and after run ,verify its belt drive improvement. pulley is available at T/S for about 8 $ . thought with the extensive detail that you were doing , i would only offer this as a suggestion / improvement . pete I had never thought about something like that, since this sort of went from a redo to more of a restoration, I think I may keep it to go with my resto-mod tractor and just redo one of my other 48" side discharge decks. Maybe the extra idler pulley would be something I could consider adding to that. Did you happen to take any pictures? Share this post Link to post Share on other sites
peter lena 10,103 #73 Posted May 7, 2020 great job on that d man ! , i have added an extra idler pulley on the long unsupported stretch on the spindle belt , simply drilling a hole to bolt the pulley to . not much pressure on the belt , just enough to take out the belt " bounce " , a before and after run ,verify its belt drive improvement. pulley is available at T/S for about 8 $ . thought with the extensive detail that you were doing , i would only offer this as a suggestion / improvement . pete Share this post Link to post Share on other sites
peter lena 10,103 #74 Posted May 7, 2020 d man , no i don,t have a picture , but on your last picture above , center deck above the tension spring, about 3 " above the single bolt head . i don,t have the belt cover frame , so i drilled just at the flat to down bend discharge chute area. you can easily see the large unsupported belt length , pulley right in the middle of that stretch, lightly pushing toward center of deck. just an experiment that i have on 5 decks , makes the deck quieter too, pete 1 Share this post Link to post Share on other sites
mmmmmdonuts 274 #75 Posted May 7, 2020 That looks fantastic. You're doing a great job. My deck has 2200 hours on it and a few holes I patched over time but it looks no where near as nice as your deck. 2 Share this post Link to post Share on other sites
