mark in ny 27 #1 Posted April 16, 2020 Is there any specific reason to use the shaker plate? Can I just bolt the engine directly to the frame with spacers instead? I may pick up a c125 but not sure if theres a shaker mount with it. Thanks guys Share this post Link to post Share on other sites
The Tuul Crib 7,354 #2 Posted April 16, 2020 I have never had a tractor with the shaker mount. All my horses bolt directly to the frame. Share this post Link to post Share on other sites
pfrederi 20,269 #3 Posted April 16, 2020 If the engine is for a shaker mount it will not direct bolt to the frame the drop in the oil pan will be in the way. you can make spacers to hold it up and may have to drill a hole or two in the frame. 1 Share this post Link to post Share on other sites
8ntruck 8,768 #4 Posted April 16, 2020 There are solid mounts available that replace the rubber mounts between the soaker tray and the frame. Check the vendor's section, or maybe another member can provide details. 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,085 #5 Posted April 16, 2020 11 minutes ago, pfrederi said: If the engine is for a shaker mount it will not direct bolt to the frame the drop in the oil pan will be in the way. you can make spacers to hold it up and may have to drill a hole or two in the frame. Solid spacers in lieu of the rubber spacers will work fine. No added effort just direct replacement... but you can’t bolt direct to frame. The spacers are on an angle raised up from the frame by two parallel mounts. Engine is cradled in between them... 6 minutes ago, 8ntruck said: There are solid mounts available that replace the rubber mounts between the soaker tray and the frame. Check the vendor's section, or maybe another member can provide details. 1 Share this post Link to post Share on other sites
mark in ny 27 #6 Posted April 16, 2020 I saw the solid mounts available but I'm not sure the shaker plate is available if it is missing. The motor I'm wanting to use bolts to the frame currently. Share this post Link to post Share on other sites
oliver2-44 11,397 #7 Posted April 16, 2020 If you have a motor that has the oil pan to mount to the frame then you can mount directly to frame no shaker plate needed. 4 Share this post Link to post Share on other sites
mark in ny 27 #8 Posted April 16, 2020 (edited) I guess I would just have to figure out height for the belt guard and pto engagement to line up correctly. Also gotta figure out where to mount to the frame so belt will work etc. The current owner is gonna check if he has it but said hes not sure. Or maybe just try and locate a shaker mount ebay or marketplace. Edited April 16, 2020 by mark in ny Share this post Link to post Share on other sites
Mikey the Monkey 701 #9 Posted April 16, 2020 @mark in ny I have a good shaker plate. I'm West of Rochester. 2 Share this post Link to post Share on other sites
WHX?? 56,076 #10 Posted April 16, 2020 (edited) Was going to say Mark one the fellas here would have a shaker plate. Some where I have the triangle pieces for underneath if you need them. Here's the solid mounts. Lots of guys just make their own but this was plug & play for me. https://www.zkbrmachine.com/category/product/-188 Edited April 16, 2020 by WHX24 1 Share this post Link to post Share on other sites
Pullstart 69,668 #11 Posted April 16, 2020 I am pretty sure that the non-shaker plate engine and the shaker plate engine both have the same height crank, as to where you’ll need no different belt guards or anything. I’m sure someone will correct me if I’m wrong... or maybe just setting the engine in place and installing the belt guard will tell? Share this post Link to post Share on other sites
pfrederi 20,269 #12 Posted April 16, 2020 If the new engine is a large base block bolted directly to the frame you can bolt it directly to your tractor just remove the shaker plate. (This assume it is from a Wheel horse, oil pans for wheel horse had 2 threaded holes in the bottom of the pan to mount to the right frame rail engines from other brands may not have the holes. You would have to source a correct oil pan or use J hooks) Share this post Link to post Share on other sites
Ed Kennell 45,739 #13 Posted April 16, 2020 (edited) I don't have a C-125, But some one on here does and I am sure they could give you the frame to crank height. I would not install a shaker plate. IMO, this was one of WHs bad ideas. Just add spacers or washers to get the engine to the proper height required for the belt guard and belt to function. Your pan should have two tapped holes on the right side that should line up with holes in the frame. If it does not have these tapped holes, some have used "J" bolts hooked under the frame on the right side. Edited April 16, 2020 by Ed Kennell Share this post Link to post Share on other sites
mark in ny 27 #14 Posted April 16, 2020 My current engine is the wide base oil pan that's mounted on a charger to the frame. I guess top of frame to center of crank would be the measurement needed to see if a shaker plate is needed or not if someone is willing to help Haha Share this post Link to post Share on other sites
pfrederi 20,269 #15 Posted April 16, 2020 I am not sure what you are trying to do..are you replacing the engine on the charger? The C-125 you are considering have an engine on it??? If it is a shaker mount and is installed what is the issue???? If you want to put a shaker mount engine (small base) directly on the frame without the shaker plate you will need spacers like this 1 Share this post Link to post Share on other sites
mark in ny 27 #16 Posted April 16, 2020 I have a charger that I just swapped a 312 motor onto it. Being it's a charger the previous owner really cobbled the front attachment mount onto it for the use of a 79360 snowblower. Angle irons pushing the hood up above the mount and a 1/2 inch plate of steel as a mounting plate behind it. Really cobbed looking to say the least but i do give credit it worked all this winter. A 1980s c series roller came up and I'd like to swap over the engine to that as its correct years for my snowblower and mower deck plus it has a hydraulic lift. So I'm looking to move the motor from the charger to the c series roller. 1 1 Share this post Link to post Share on other sites
pfrederi 20,269 #17 Posted April 16, 2020 OK Got it. That will be easy. just throw away the shaker mount on the c125 and bolt on your charger engine....Everything should line up. 1 Share this post Link to post Share on other sites
Ed Kennell 45,739 #18 Posted April 16, 2020 Good move....You'll luv the hyd lift when blowing snow. Then look for a cab and a foot motion control. Share this post Link to post Share on other sites
mark in ny 27 #19 Posted March 4, 2021 Revisiting this topic as I just purchased a shaker plate k341. I want to direct bolt to the frame does anyone have the measurement of the spacer needed to direcr bolt? Thanks Share this post Link to post Share on other sites
The Tuul Crib 7,354 #20 Posted March 4, 2021 OK 341 should bolt directly to your frame. The right side should hang over the frame and bolt in the bottom . The left side should bolt through the oil pan. Share this post Link to post Share on other sites
pfrederi 20,269 #21 Posted March 4, 2021 (edited) No a shaker plate (small base K341) will not hang over the side, the oil pan is smaller. You will need some spacers. like these Edited March 4, 2021 by pfrederi Share this post Link to post Share on other sites
mark in ny 27 #22 Posted March 4, 2021 22 minutes ago, pfrederi said: No a shaker plate (small base K341) will not hang over the side, the oil pan is smaller. You will need some spacers. like these Any idea the spacer thickness? Share this post Link to post Share on other sites
pfrederi 20,269 #23 Posted March 4, 2021 You need 3/4" lift. I used the half inch thick spacers from a K181 shaker mount plus 3 SAE washers to get it. 1 Share this post Link to post Share on other sites
