bo dawg 643 #1 Posted April 10, 2020 Ive always wanted to do a wheel project painting the rim 1 color, and the back mounting plate another color. With it looking good and separated. Any tricks? And how long to wait between colors when taping off? Thanks Bo Share this post Link to post Share on other sites
bo dawg 643 #2 Posted April 10, 2020 3 hours ago, bo dawg said: Ive always wanted to do a wheel project painting the rim 1 color, and the back mounting plate another color. With it looking good and separated. Any tricks? And how long to wait between colors when taping off? Thanks Bo Share this post Link to post Share on other sites
953 nut 70,073 #3 Posted April 10, 2020 I've never been that bored, guess that is why I use hub caps. But, if I wanted to paint two tone rims I would paint the entire rim the color you want for the backing plate. After a week or more I would mask off the plate area on both sides and paint the rim. 3 2 Share this post Link to post Share on other sites
Achto 32,896 #4 Posted April 11, 2020 6 hours ago, bo dawg said: And how long to wait between colors when taping off? This question really depends on what paint you are using. If you are using an automotive grade base coat / clear coat paint it could be as little as 30min. If you are using Rustoleum It will be more like 7 to 8 days. Carefully read the instructions on the paint that you are using, it should have a recoat time on it. 6 Share this post Link to post Share on other sites
8ntruck 9,368 #5 Posted April 11, 2020 Paint the lighter color first. 3 Share this post Link to post Share on other sites
bo dawg 643 #6 Posted April 11, 2020 4 hours ago, 953 nut said: I've never been that bored, guess that is why I use hub caps. But, if I wanted to paint two tone rims I would paint the entire rim the color you want for the backing plate. After a week or more I would mask off the plate area on both sides and paint the rim. That's what I was thinking but wasn't sure how long to wait to safely mask off fresh paint. I would be using rattle can rustoleum, and more than likely Farm Implement. Thanks 1 Share this post Link to post Share on other sites
JoeM 10,317 #7 Posted April 11, 2020 3 hours ago, bo dawg said: I would be using rattle can rustoleum, and more than likely Farm Implement Ir maybe longer than 7 days, check it before you mask. I have already had to wait a month with Rattle can paint. Leaving the parts out in the Sun can help dry the paint too. 3 Share this post Link to post Share on other sites
bo dawg 643 #8 Posted April 11, 2020 3 hours ago, TractorJunkie said: Ir maybe longer than 7 days, check it before you mask. I have already had to wait a month with Rattle can paint. Leaving the parts out in the Sun can help dry the paint too. That would suck to wait longer cause Im impatient on everything I do. Lol! 1 2 Share this post Link to post Share on other sites
bo dawg 643 #9 Posted April 11, 2020 (edited) Anyone know what the inside dimension is of the wheel? I would take paper stock and lay it inside. I took the bottom of a bucket and it started to go inside and it was 10 3/16" Edited April 11, 2020 by bo dawg Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #10 Posted April 12, 2020 I sorta did it to my 1054...semi gloss black and silver. 3 2 Share this post Link to post Share on other sites
bo dawg 643 #11 Posted April 13, 2020 13 hours ago, Sparky said: I sorta did it to my 1054...semi gloss black and silver. That's it Mike. That's what I am thinking about. Not sure which colors for sure but rim one color and mount plate another. How did you go about it, and how long wait in between colors?? Share this post Link to post Share on other sites
Sparky-(Admin) 26,621 #12 Posted April 13, 2020 Disclaimer: I have little to no paint skills AND even less patience . Here’s the thread on the 1054 rims. 3 Share this post Link to post Share on other sites
