Tractor boy 239 #1 Posted April 9, 2020 Key switch burned on my 1056 last night. Tractor is okay but switch isn’t. Diagram shows it is part nunber 4988. Doesn’t cross anywhere, i was wondering if anyone knows if O’Reillys or napa would have it. Share this post Link to post Share on other sites
ebinmaine 75,774 #2 Posted April 9, 2020 If that's a regular Kohler 10 horse with a battery points type ignition... Does it have a switch with two heavy leads , one small one, three total? Share this post Link to post Share on other sites
Tractor boy 239 #3 Posted April 9, 2020 Yessir. Same engine in the other thread i started. Share this post Link to post Share on other sites
Tractor boy 239 #4 Posted April 9, 2020 Toro wants $50, rotary is $30 Share this post Link to post Share on other sites
ebinmaine 75,774 #5 Posted April 9, 2020 Somebody might pop on here and give you the correct part number before I get home later on. There are good aftermarket switches available from Standard Motor Parts or Cole Hersee, maybe BorgWarner. Seems as though I ordered one from my local Parts Plus affiliate and it was like $22, $24? Share this post Link to post Share on other sites
ebinmaine 75,774 #6 Posted April 9, 2020 We think you REALLY do want to do in this situation is to replace the battery cables themselves. Believe it or not that might be a huge part of your issue. Share this post Link to post Share on other sites
Tractor boy 239 #7 Posted April 9, 2020 Cables are getting replaced as well....key was actually smoking 1 Share this post Link to post Share on other sites
ebinmaine 75,774 #8 Posted April 9, 2020 4 minutes ago, Tractor boy said: ....key was actually smoking Share this post Link to post Share on other sites
pfrederi 19,276 #10 Posted April 9, 2020 Cole hersee 95521 Is a heavy duty three terminal switch for battery igniton that can handle the heavy starting current draw. One source I found http://www.partdeal.com/cole-hersee-ignition-switch-3-position-95521-b-bx.html 2 Share this post Link to post Share on other sites
ebinmaine 75,774 #11 Posted April 9, 2020 10 minutes ago, pfrederi said: Cole hersee 95521 Is a heavy duty three terminal switch for battery igniton that can handle the heavy starting current draw. One source I found http://www.partdeal.com/cole-hersee-ignition-switch-3-position-95521-b-bx.html That's the one!. Thanks Paul. Share this post Link to post Share on other sites
cafoose 3,524 #12 Posted April 9, 2020 I would recommend converting over to a solenoid and 5 terminal switch. I did this to my 876 and I'm very glad I did. This thread should explain how with wiring diagrams: 2 Share this post Link to post Share on other sites
Tractor boy 239 #13 Posted April 9, 2020 Okay thanks. 5 terminal switches are plain old regular modern lawn mower switches right? I think i might have one i can use on a parts tractor with a blown engine and transmission. Thanks, Tractorboy Share this post Link to post Share on other sites
ebinmaine 75,774 #14 Posted April 9, 2020 29 minutes ago, Tractor boy said: . 5 terminal switches are plain old regular modern lawn mower switches right? Be VERY careful there... There are several types. The 2 main ones for Horses are 103990. Battery points ignition. 103991. Magneto ignition. They can't be mixed. Check the terminal letters to see what they read. B. Or. M. Will be on one fo the terminals. Solenoid from alot of old vehicles can be used or a small 3 terminal universal type. Share this post Link to post Share on other sites
953 nut 63,044 #15 Posted April 10, 2020 103 990 switch used in this drawing. Share this post Link to post Share on other sites
new2horses 287 #16 Posted April 10, 2020 I have the correct Cole Hersee 70 amp in stock and can put one in the mail to you for $40.00. This is a new switch and is exactly the same switch as was originally installed, comes with 2 keys Pay pal friendly PM me here for my email and with your shipping info. If you want to go that route.. David Share this post Link to post Share on other sites
moe1965 766 #17 Posted April 10, 2020 I agree cafoose. I converted my 856 ignition over. I am by no means good with wiring but I recieved a lot of help from people on this sight which I am grateful for . I got through it I'm sure you can to with help from this great bunch on red squares 1 Share this post Link to post Share on other sites
Tractor boy 239 #18 Posted April 11, 2020 9 hours ago, new2horses said: I have the correct Cole Hersee 70 amp in stock and can put one in the mail to you for $40.00. This is a new switch and is exactly the same switch as was originally installed, comes with 2 keys Pay pal friendly PM me here for my email and with your shipping info. If you want to go that route.. David I am all set. Friend of mine who runs the local toro dealer gave me a switch and solenoid. He owed me some money....... thanks for the help guys. Tractorboy Share this post Link to post Share on other sites
