3WHDave 60 #1 Posted April 9, 2020 I am new to this board, so I apologize in advance if my question has already been addressed, or if this is the wrong place to pose this question: where may I find a wiring schematic for a D-180? Is it the same as a D-160? I am trying to determine if the lack of any ignition response (no sound what so ever) is due to an inter-lockout safety switch. Also looking for both owners manual and service manual. I only find D-160. Share this post Link to post Share on other sites
WHX?? 53,318 #2 Posted April 9, 2020 Dave Lots of D experts here. Upper right hand search block put in D-180, then click more options and search in files and you will find every thing you are looking for and then some. Share this post Link to post Share on other sites
Pullstart 68,521 #3 Posted April 9, 2020 @3WHDave welcome! I assume you’re in northern MI? Try this manual here for D-180 Wiring Here is a link to D-180 in general, specific to files on the forum. hope that helps! 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,813 #4 Posted April 9, 2020 Good to see another Michigander! Spent many a winter weekend in and around Boyne City!!! Share this post Link to post Share on other sites
3WHDave 60 #5 Posted April 9, 2020 Thank you both, and yes, Northern Michigan. My main house is on the outskirts of Denver, and I did not flee do to COVID, it was simply timing that I was here a month before all H***L broke loose. Ironically, my company (Wi Inc) designed and manufactures the regent components and micro-fluid components for GenMark, 1st COVID test approved by FDA. Check them out, very ethical and hard working group of people (public). Back on topic, The problem turned out to be a totally corroded and useless ignition switch. I was able to bypass the switch and perform a dry-run turn of the engine. Next on the list: TSP the inside of the tank and replace all fuel lines, rebuild carb, 1 Share this post Link to post Share on other sites
