Kennyk 1 #1 Posted April 5, 2020 Hello, I am a newbi to the forum. I have a 1989 -1990 wheel horse 520H that looses power on an uphill slope. There is a squealing noise and feels as if the drive belt is slipping. Upon inspection I noticed a broken spring hanging down from the lever behind the pulley that is between the engine and transaxle. I can replace the spring but not sure where to hook the other end to. I am assuming this would create better tension on the belt. Any help would be appreciated. 1 Share this post Link to post Share on other sites
WHX?? 57,501 #2 Posted April 5, 2020 The spring hooks on a tab in back of the pully to a hole just below it. You can just see the tab here. Sorry doesn't show the lower hook hole. Was trying to show the bad bearing but check that and the condition of the drive belt. Share this post Link to post Share on other sites
Kennyk 1 #3 Posted April 6, 2020 Thanks, I did attach the other end to the closest hole below this tab. I didn't stretch the spring or put tension on it. I was't sure if this was the correct hole. It didn't seem to make any difference. the belt seems to still be slack. I'll try and pull some panels off tomorrow to get a better look. Any other ideas would be appreciated. Share this post Link to post Share on other sites
WHX?? 57,501 #4 Posted April 6, 2020 Shouldn't need to pull anything off but the belt guard. Spring should have quite a bit of tension on it. Share this post Link to post Share on other sites
Kennyk 1 #5 Posted April 6, 2020 Thanks I'll attack this demon tomorrow. Share this post Link to post Share on other sites
mechanic28 5 #6 Posted April 6, 2020 Here is a picture of the spring in question attached to a fixed point on the chassis at the bottom of the spring and a tab on the idler arm at the top. Just myself replacing the idler pulley which will put quite a bit of tension on the belt when installed with the spring loaded. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #7 Posted April 6, 2020 14 minutes ago, mechanic28 said: Here is a picture of the spring in question attached to a fixed point on the chassis at the bottom of the spring and a tab on the idler arm at the top. Just myself replacing the idler pulley which will put quite a bit of tension on the belt when installed with the spring loaded. Hope this helps... Share this post Link to post Share on other sites
Kennyk 1 #8 Posted April 6, 2020 Perfect!! Pictures really helped. Runs strong again. Now if I am not pushing my luck, do you know what oil filter I could use from an auto store. Our Toro dealer is shut down because of virus. Again thank you. Ken Share this post Link to post Share on other sites
WHX?? 57,501 #9 Posted April 6, 2020 Napa 1410 hydro filter & Napa 1762 engine oil filter... Napa 1763 has the hex on the end. Share this post Link to post Share on other sites
WHX?? 57,501 #11 Posted April 6, 2020 Your ....anytime Share this post Link to post Share on other sites
