TomB 2 #1 Posted March 31, 2020 can't shift into gear when engine is running Share this post Link to post Share on other sites
953 nut 59,886 #2 Posted March 31, 2020 If you do not have the belt guard on the drive belt will not stop when you push in the clutch. 3 Share this post Link to post Share on other sites
rjg854 12,175 #3 Posted March 31, 2020 Is the drive belt cover on? Does it just grind? Please tell us more. Share this post Link to post Share on other sites
TomB 2 #4 Posted March 31, 2020 put a new air filter on and have covers off....shifted fine before can't get it into any gear 1 Share this post Link to post Share on other sites
TomB 2 #5 Posted March 31, 2020 thanks...,I'll try your recommendation. Share this post Link to post Share on other sites
Pullstart 66,688 #6 Posted March 31, 2020 If that doesn’t help... which it should... let us know what model we’re working on 2 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #7 Posted March 31, 2020 And. Most of all DO NOT force it!! Not good on the shifter forks!! and TO Share this post Link to post Share on other sites
Ed Kennell 41,910 #8 Posted March 31, 2020 (edited) Just curious, why take the belt guard off to install a new air filter? The belt guard has two functions; 1. to protect the operator from injury 2. to support the drive belt when the clutch is depressed. This prevents the belt from contacting the engine pulley and allows the belt to stop so the transmission gears can be shifted. The tractor transmission can not be operated without the drive belt guard in working order and in place. Edited March 31, 2020 by Ed Kennell 3 Share this post Link to post Share on other sites
TomB 2 #9 Posted March 31, 2020 Didn't take the belt guard off for the air filter. I need to do some welding so that's why the belt guard is off. Thanks for your response. 1 1 Share this post Link to post Share on other sites
953 nut 59,886 #10 Posted March 31, 2020 25 minutes ago, TomB said: Thanks for your response Now that the mystery is solved please tell us about your and a bit about yourself. Share this post Link to post Share on other sites
The Tuul Crib 7,339 #11 Posted March 31, 2020 6 minutes ago, 953 nut said: Now that the mystery is solved please tell us about your and a bit about yourself. Share this post Link to post Share on other sites
Ed Kennell 41,910 #12 Posted March 31, 2020 1 hour ago, TomB said: Didn't take the belt guard off for the air filter. I need to do some welding so that's why the belt guard is off. Thanks for your response. Was there anything broken or missing on the belt guard? Some models have belt support tabs have tabs that break off. Can we see pictures of your tractor and what needs welding? 2 Share this post Link to post Share on other sites
