peter lena 10,047 #51 Posted April 1, 2020 wv hunter , just snooping around on facebook and found ,https://www.facebook.com/groups/720778008002796/ there is a wheel horse groupe near you ! you can find help there , pete 1 Share this post Link to post Share on other sites
Wishin4a416 2,610 #52 Posted April 1, 2020 On 3/30/2020 at 8:00 PM, wvhunter said: does anyone know if it would have 1 or 1 1/8 axle? I am wanting one to plow a garden with it. It came with either or. My 87 312 has the big axles. Share this post Link to post Share on other sites
wvhunter 88 #53 Posted April 1, 2020 2 hours ago, peter lena said: wv hunter , just snooping around on facebook and found ,https://www.facebook.com/groups/720778008002796/ there is a wheel horse groupe near you ! you can find help there , pete thank you very much!!! Share this post Link to post Share on other sites
peter lena 10,047 #54 Posted April 1, 2020 wvhunter , contact this guy , pete Share this post Link to post Share on other sites
wvhunter 88 #55 Posted April 1, 2020 9 hours ago, gwest_ca said: 1990 or newer because of the black on the decals. 1989 and older were maroon. If still readable this decal has the important numbers. Axles should be 1-1/8" diameter and the differential should have 8 pinion gears. It does not get any better. Garry I found these numbers, 3112K801 15413 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #56 Posted April 1, 2020 Click on the fuzzy picture for more info Garry 2 Share this post Link to post Share on other sites
wvhunter 88 #57 Posted April 1, 2020 I drained the gas and took gas lines loose and took air hose and blowed them out.also took bowl off of carburetor and cleaned it out. started purring like a kitten, motor sounds good and all the gears work good.thanks for your help 1 4 Share this post Link to post Share on other sites
wvhunter 88 #58 Posted April 1, 2020 16 minutes ago, gwest_ca said: Click on the fuzzy picture for more info Garry thank you Share this post Link to post Share on other sites
ebinmaine 80,628 #59 Posted April 1, 2020 10 minutes ago, wvhunter said: I drained the gas and took gas lines loose and took air hose and blowed them out.also took bowl off of carburetor and cleaned it out. started purring like a kitten, motor sounds good and all the gears work good.thanks for your help Super awesome that it runs. We'd love to see video. not sure how time-consuming it's going to be but you definitely need to replace that fuel line. Do you have access to non ethanol gas in your area? Share this post Link to post Share on other sites
wvhunter 88 #60 Posted April 1, 2020 1 minute ago, ebinmaine said: Super awesome that it runs. We'd love to see video. not sure how time-consuming it's going to be but you definitely need to replace that fuel line. Do you have access to non ethanol gas in your area? yes sir, I am planning on replacing the lines. I just wanted to see if I could get it running for know. I don't know for sure where I can get ethanol gas at though. I will find out,not getting out much know because of this virus, I will try and post video of it running, thanks for the help 1 1 Share this post Link to post Share on other sites
ebinmaine 80,628 #61 Posted April 1, 2020 Check out pure-gas.org 1 Share this post Link to post Share on other sites
tom2p 2,396 #62 Posted April 1, 2020 21 hours ago, peter lena said: wvhunter , just did a quick look up on your pto clevis shaft point ,, good brake down pictures , you will need , bearing ,snap ring, shaft . wheel horse parts available on this site , pete pete - how (in the heck) were you able to determine there was an issue with the PTO shaft ? from just one pic that showed that area - and it was not a close up or zoom ... eagle eyes pete ? from that pic I did notice the brake pedal appears to be back a bit more than typical (toward rear) ... ? ... 1 Share this post Link to post Share on other sites
peter lena 10,047 #63 Posted April 1, 2020 just the look of the galled bearing shell , and the fact that the pto shaft is in the middle of it tells me that is part of the failure . i have replaced the bearings and shafts on my 3 tractors , due to past owner neglect, don,t wait for a failure , regularly check out that pto set up , stay after it , pete Share this post Link to post Share on other sites
wvhunter 88 #64 Posted April 1, 2020 1 hour ago, ebinmaine said: Super awesome that it runs. We'd love to see video. not sure how time-consuming it's going to be but you definitely need to replace that fuel line. Do you have access to non ethanol gas in your area? got a video of it running on the phone, but cannot get it transferred to laptop to post, sorry 1 Share this post Link to post Share on other sites
wvhunter 88 #65 Posted April 1, 2020 (edited) 3 hours ago, wvhunter said: got a video of it running on the phone, but cannot get it transferred to laptop to post, sorry finally figured out how to post video u=https%3A%2F%2Fyoutu.be%2FdrZSqkpEer4%3Ffbclid%3DIwAR2eYK_T8pX0xdU4CY6kg1JyUTgbZST5cUvgFTz1ZnBbIgxif1DhoOuZv_A&h=AT017BPmTRXWXDaNQALj_Z5eG6aDJY7nNbJE5NhEIc_6W81sM88-bfbLyqGoZx1oGiyW_Z2tUbxsB85L95_b1i_WQBGy2KFqLlHbazzMSmebCTCunnQCgsDtPIVl9Y-RWvB8nw Edited April 2, 2020 by wvhunter video did not load 4 Share this post Link to post Share on other sites
River19 87 #66 Posted April 1, 2020 18 minutes ago, wvhunter said: finally figured out how to post video https://l.facebook.com/l.php?u=https%3A%2F%2Fyoutu.be%2FdrZSqkpEer4%3Ffbclid%3DIwAR2eYK_T8pX0xdU4CY6kg1JyUTgbZST5cUvgFTz1ZnBbIgxif1DhoOuZv_A&h=AT017BPmTRXWXDaNQALj_Z5eG6aDJY7nNbJE5NhEIc_6W81sM88-bfbLyqGoZx1oGiyW_Z2tUbxsB85L95_b1i_WQBGy2KFqLlHbazzMSmebCTCunnQCgsDtPIVl9Y-RWvB8nw Sounds pretty decent after the initial surging....probably had the choke on there anyways.......again, not a bad score. Now that it is running......about that cup holder...... 1 1 Share this post Link to post Share on other sites
tom2p 2,396 #67 Posted April 1, 2020 (edited) 1 hour ago, peter lena said: just the look of the galled bearing shell , and the fact that the pto shaft is in the middle of it tells me that is part of the failure . i have replaced the bearings and shafts on my 3 tractors , due to past owner neglect, don,t wait for a failure , regularly check out that pto set up , stay after it , pete you were able to see a galled bearing shell in the pic below ? you must have chuck yeager eyes ! ( or a giant screen / monitor ? ) Edited April 1, 2020 by tom2p Share this post Link to post Share on other sites
tom2p 2,396 #68 Posted April 1, 2020 22 minutes ago, wvhunter said: finally figured out how to post video https://l.facebook.com/l.php?u=https%3A%2F%2Fyoutu.be%2FdrZSqkpEer4%3Ffbclid%3DIwAR2eYK_T8pX0xdU4CY6kg1JyUTgbZST5cUvgFTz1ZnBbIgxif1DhoOuZv_A&h=AT017BPmTRXWXDaNQALj_Z5eG6aDJY7nNbJE5NhEIc_6W81sM88-bfbLyqGoZx1oGiyW_Z2tUbxsB85L95_b1i_WQBGy2KFqLlHbazzMSmebCTCunnQCgsDtPIVl9Y-RWvB8nw sounds great - whatta find ! 1 Share this post Link to post Share on other sites
peter lena 10,047 #69 Posted April 1, 2020 tom2p, the first picture you sent , that was right up on the pto drive shaft lever point , told me what was going on , when you look at the facebook site i sent , and scroll down on pictures , there is a stack of pto drive pulleys , and the guys name , easy to see the complete drive pulley with intact drive shaft . that is what you want , pete 1 Share this post Link to post Share on other sites
wvhunter 88 #70 Posted April 1, 2020 27 minutes ago, River19 said: Sounds pretty decent after the initial surging....probably had the choke on there anyways.......again, not a bad score. Now that it is running......about that cup holder...... I was working the throttle a little to much I believe,sadly the cup holder has been removed 1 Share this post Link to post Share on other sites
ebinmaine 80,628 #71 Posted April 1, 2020 56 minutes ago, wvhunter said: finally figured out how to post video If you go to your YouTube video and click share, then copy, you can paste it right to these pages. Share this post Link to post Share on other sites
wvhunter 88 #72 Posted April 1, 2020 Just now, ebinmaine said: If you go to your YouTube video and click share, then copy, you can paste it right to these pages. i posted a link to video 1 Share this post Link to post Share on other sites
ebinmaine 80,628 #73 Posted April 2, 2020 28 minutes ago, wvhunter said: i posted a link to video I got through to it ok but often can't open or use Facebook links as I don't have an account. 1 Share this post Link to post Share on other sites
wvhunter 88 #74 Posted April 2, 2020 1 minute ago, ebinmaine said: I got through to it ok but often can't open or use Facebook links as I don't have an account. 1 hour ago, wvhunter said: finally figured out how to post video u=https%3A%2F%2Fyoutu.be%2FdrZSqkpEer4%3Ffbclid%3DIwAR2eYK_T8pX0xdU4CY6kg1JyUTgbZST5cUvgFTz1ZnBbIgxif1DhoOuZv_A&h=AT017BPmTRXWXDaNQALj_Z5eG6aDJY7nNbJE5NhEIc_6W81sM88-bfbLyqGoZx1oGiyW_Z2tUbxsB85L95_b1i_WQBGy2KFqLlHbazzMSmebCTCunnQCgsDtPIVl9Y-RWvB8nw sorry cannot get video to play 1 Share this post Link to post Share on other sites
Guest 88vic #75 Posted April 2, 2020 Wvhunter how close are you Pennsylvania? Share this post Link to post Share on other sites
