HokieAg07 129 #1 Posted March 22, 2020 Anyone have an aftermarket solution to the rocker switch used on for the headlights on a later model 520? Not opposed to spending $20 on OEM Toro but I would bet I can get the same thing much cheaper. Share this post Link to post Share on other sites
ebinmaine 75,751 #2 Posted March 22, 2020 I've had mixed results with using "cheap" electrical products the last few years. I'd have agreed and done the same maybe 5 years ago. After having some ignition switch and headlight switches be poor quality in the 10 to 15 dollar range .... You're better off spending the $20 at Toro for OEM. 1 Share this post Link to post Share on other sites
lynnmor 8,256 #3 Posted March 22, 2020 2 hours ago, HokieAg07 said: Anyone have an aftermarket solution to the rocker switch used on for the headlights on a later model 520? Not opposed to spending $20 on OEM Toro but I would bet I can get the same thing much cheaper. I bet you are correct, it you wade thru this catalog you just might find it. If you can get any numbers off the switch, that might help. Take measurements of the opening as well. I found a number of the safety switches that are exactly the same for a small fraction of Toro's price. Share this post Link to post Share on other sites
