WildmanC120 613 #1 Posted March 17, 2020 (edited) What are the differences between the KT and M series? Will the KT series blower housing fit a M series? Might sound weird but I like the look of the KT series better with the exposed flywheel screen spinning, like a K series over the M series with that giant screen over everything. Edited March 17, 2020 by WildmanC120 Share this post Link to post Share on other sites
pfrederi 20,261 #2 Posted March 17, 2020 Blower housing would fit. Other shields are related to spec number ( Buyer) not Kt vs M. Other wise KT has battery points M has Magneto. Share this post Link to post Share on other sites
WildmanC120 613 #3 Posted March 17, 2020 So is the Magnum pretty much just a series 2 with magneto? Share this post Link to post Share on other sites
pfrederi 20,261 #4 Posted March 17, 2020 Yes Depending on Spec # may have oil pressure port. 3 Share this post Link to post Share on other sites
WildmanC120 613 #5 Posted March 17, 2020 9 minutes ago, pfrederi said: Yes Depending on Spec # may have oil pressure port. Cool thanks. Only issue is I don't think the magnum flywheel is drilled for the screen to mount on it Share this post Link to post Share on other sites
pfrederi 20,261 #6 Posted March 18, 2020 Guess i will have to take a look at my 418 vs one of the C175s 1 Share this post Link to post Share on other sites
WildmanC120 613 #7 Posted March 18, 2020 9 hours ago, pfrederi said: Guess i will have to take a look at my 418 vs one of the C175s That would work. Thanks So the reason I am asking this is because I have my 418-c basically stripped down to a frame. I've want a c-175/165 really bad. I love the look of the KT engine. The exposed flywheel is great. So I am gonna change the dash and tower on my 418 and get a black hood and make my own 175/165. Share this post Link to post Share on other sites
Pullstart 69,652 #8 Posted March 18, 2020 59 minutes ago, WildmanC120 said: That would work. Thanks So the reason I am asking this is because I have my 418-c basically stripped down to a frame. I've want a c-175/165 really bad. I love the look of the KT engine. The exposed flywheel is great. So I am gonna change the dash and tower on my 418 and get a black hood and make my own 175/165. I’m still out of reactions for the day... Make sure to do a build thread on that! 1 Share this post Link to post Share on other sites
WildmanC120 613 #9 Posted March 18, 2020 19 minutes ago, pullstart said: I’m still out of reactions for the day... Make sure to do a build thread on that! Sure I can do that. It should be easy as it's the same frame. Literally just change the dash tower for the hood you want in this case going with a black hood. I have the entire 418-c machine so have most all the other parts. Just gonna make a black hood with a magnum 18. Probably gonna do 520 steering. 1 Share this post Link to post Share on other sites
pfrederi 20,261 #10 Posted March 18, 2020 Looked at my magnum. Not drilled and tapped...however 4 of the fins have a small 1/4"+/- stud like projection that may be used to hold a screen. hard to see with out removing the outer screen. Not not all M18 had the big outside screen there were a couple of styles of smaller flywheel only screen. 1 Share this post Link to post Share on other sites
WildmanC120 613 #11 Posted March 18, 2020 30 minutes ago, pfrederi said: Looked at my magnum. Not drilled and tapped...however 4 of the fins have a small 1/4"+/- stud like projection that may be used to hold a screen. hard to see with out removing the outer screen. Not not all M18 had the big outside screen there were a couple of styles of smaller flywheel only screen. Thanks for that. I'll have to dig I to it later. Share this post Link to post Share on other sites
