Countdown To Christmas!
bigbore1934
K181s B-80 fuel pump
bigbore1934
Just got my new diaphragm kit from THEN-NOW-AUTO installed the new diaphragm ,drainback valves and all,reinstalled it and let the gasket sealer dry....i tightened the screws what I would call tight,I didn't want to cut the rubber so I was cautious....well it sprayed gas clear out on the front tire!
Should the screws be super tight?
Taking it back off,I found it had put gas in the engine after only running for 30 seconds...it raised the oil level and ran out of the arm area of the fuel pump when I removed it...
Is this an issue of just being to careful?
I could find no flaws or damage to any of the parts.
briankd
i had an issue with their pump diaphragm my k 181 pulse pump worked fine but  i got a diaphragm kit for my k 301 it had a lever on the diaphragm and it wouldn't pump after i installed it . i called them and they said to loosen the screws and then re tighten and never did work so i kept the old diaphragm in it .i never had gas to come out of mine on my k 181  it worked fine the screws shouldn't be super tight mine aluminum and was afraid of striping the threads out . that is weird that gas would come out lever hole after rebuild and  diaphragm  has no damage. i would think the diaphragm has a cut in it   gas is only to be on one side of it if it goes thru it  will go into crankcase
Edited by briankd
The Tuul Crib
:text-welcomeconfetti:To :rs:
I am myself recently got done rebuilding a 14 horse and made a mistake of putting a cheap Chinese fuel pump which drained
gas into the crank case and did some damage. Since I have decided to go with an electric fuel pump. Instant starts every time. of course the original pumps are OK
and work fine, but from now on I am sticking with electric .
:wwp:
  • Like 3
bigbore1934
So the company advised that I belt sand the aluminum housing until there is a flat mating surface...well I held it together over a light and it was crazy warped,so a little sanding and it fits together with no daylight! It's all reassembled and ready for try #2! Wish I had thought of that!😆
