bo dawg 565 #1 Posted April 29, 2009 My Charger 12 is missing the spring to hold the foot pedal up. Which I need to get one of course, but where exactly does it attach at? I have a copy of a manual but the pictures are bad and can't tell where it would go (if it even shows). :dunno Do I need an exact replacement spring? :omg: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted April 29, 2009 The spring is located inside the hoodstand "console" area and attaches to the neutral cam plate on the DCL. The other end is either fastened to a bolt that screwed through the side of the hoodstand or through a small hole drilled in the bottom of the rear sloped section of the hoodstand. (depends on the year) The spring was P/N 1230 but is now NLA. I think P/N 83-2820 will work in it's place but it's not cheap. I'm going from memory only, but I think the spring is around two inches long and about 3/8" to 1/2" in diameter and is fairly light gauge wire. You might be able to find one that's compatible at a hardware or automotive parts store. Good luck if you decide to install the spring in the original location. You might end up putting one on the outside somewhere once you invent twelve new swear words and pull most of your hair out. :omg: Share this post Link to post Share on other sites
bo dawg 565 #3 Posted April 29, 2009 I would of guessed it attaching the other direction and not to the hood stand. Sounds good, thank you TT, you rock my friend I will try to find a spring that works, and hopefully keep my sanity :( Share this post Link to post Share on other sites
Duff 206 #4 Posted April 29, 2009 .....once you invent twelve new swear words and pull most of your hair out. Isn't that half the fun of working on these little beasts? Duff :drool: Share this post Link to post Share on other sites
