76c12091520h
106120 IDLER SUPPORT BARS!
76c12091520h
Brand new ! Manufactured by us - 106120 idler support bars. Exact replacement for your worn out , corroded , or missing bars found on most all later model decks. Epoxy coated for durability.  $35.00 + shipping.  We also have the 107674 / 107675 bushings and washers in stock at all times. Please do not comment on this post. Private message me thru the Red Square messenger or call /text during normal business hours.
Edited by 76c12091520h
  • Excellent 5
Don66
Does this fit the 36"  3-blade mower deck?
cleat
Those look awesome.
I don't need one right now but glad to see they are being reproduced.
Thanks for helping our cause.
gmcd
what is the best time to call and order
RaySykes
are these still available Part Number: 106120?
How do I purchase 106120 idler support bar from you
76c12091520h
Send me a private message.....
peter lena
@76c12091520h  have also added a flat idler pulley , on the back unsupported side of that belt , over 20 " of unsupported belt bounce ! get a 3 " flat pulley , re grease it , test trial your location , about middle of bounce zone , light push against belt , drill deck hole , like a 3/8 " thread free bearing area , then flat washer both bottom , and top  of bolt to deck , elastic lock nut . lots of hours and zero issues . BTW belt bounce is related to bearing lubricant issues , the more bounce you have the , mor collective bearing drag you have . how easily does your deck MOVE BY HAND ? at the mule drive area ? that tells the  status of drag on your set up . . should be easy / smooth , pete
76c12091520h
As stated above,  please do not comment on these posts...
cjonspino
Bought two.
Look and work great.
Thank you
