peter lena 9,316 #1 Posted February 19, 2020 having these in all my work areas , its the go to on making a linkage ,lever or an electrical corrosion issue get back to work , https://www.amazon.com/Super-Lube-52004-Lightweight-Translucent/dp/B00175VGUA/ref=pd_sbs_328_t_1/135-8254709-8762636?_encoding=UTF8&pd_rd_i=B00175VGUA&pd_rd_r=73f16a65-88c1-4063-a9fd-2fe8d7ccff76&pd_rd_w=pdFlN&pd_rd_wg=yWxC0&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=MGBCA3AYN4QQ80BMSNE6&psc=1&refRID=MGBCA3AYN4QQ80BMSNE6. it stands up and creeps into anything , got a sealed bearing that is acting up ? put some of this on the grease seal edge, and watch it bubble up ,while its sucking it in , and smoothing it out. cable lubricant, carb linkage, pto lever rusty and stiff ? make it work again. its also a dielectric synthetic oil. i use it so often i do not even think about it, you will too, pete Share this post Link to post Share on other sites
Sparky-(Admin) 23,307 #2 Posted February 19, 2020 Thanks for the link Pete...and its inexpensive to boot! 1 Share this post Link to post Share on other sites
lynnmor 7,858 #3 Posted February 19, 2020 It is also food grade, so you can use it on your pancakes. 1 1 Share this post Link to post Share on other sites
