oldredrider 2,553 #1 Posted February 8, 2020 Picked up a crate of Wheel Horse parts. Included was a disassembled K-241 for a 953. Putting the engine back together and have gotten to the point where I need to know how the throttle is routed/hooked up to the engine. I have tons of engine parts so variations are not a problem. What I would like to see are pics of the proper routing of the throttle cable and governor hook up. Would like this motor to be a plug and play for anyone interested in it. Thanks for any assistance. Share this post Link to post Share on other sites
953 nut 61,052 #2 Posted February 8, 2020 Here you go. 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,003 #3 Posted February 8, 2020 On a C 105...Hope these help... Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted February 8, 2020 (edited) 4 hours ago, 953 nut said: Here you go. Thanks Richard. That's exactly what I was looking for! Edited February 8, 2020 by oldredrider 1 Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted February 10, 2020 After digging through all the parts, I came up with these guys. Apparently, this engine uses a shorter linkage rod which hooks up to the throttle cable like this: Notice the throttle cable clamp is mounted to the shroud. Share this post Link to post Share on other sites
953 nut 61,052 #6 Posted February 11, 2020 6 hours ago, oldredrider said: the throttle cable clamp is mounted to the shroud That clamp is for the choke cable, the one on the breather/valve cover is for the throttle. Should work fine. Share this post Link to post Share on other sites
oldredrider 2,553 #7 Posted February 11, 2020 Not shown in the pic but there is a clamp for the choke cable mounted in the conventional spot. The throttle cable mounted in the shroud clamp lines up perfectly with the linkage angle thingy. If you look closely at your pic, there is a mounting hole for a clamp on your shroud. 1 Share this post Link to post Share on other sites
