ebinmaine 79,789 #101 Posted March 10, 2020 On the tractors we've done the hub lines up flush with the end of the axle on both sides Share this post Link to post Share on other sites
Psychonova68 36 #102 Posted March 10, 2020 That's what I figured, I measured from center line and they are about the same. I would guess that any small differences would be managed by the differential. 1 Share this post Link to post Share on other sites
Psychonova68 36 #103 Posted March 11, 2020 What's the oil capacity for the 5060? Can't seem to find the owner's manual for it. Share this post Link to post Share on other sites
WHX?? 57,501 #104 Posted March 11, 2020 Not sure of the exact amount but here's what I do. Take off the left side filler.. a 3/8" plug with a coupling and nipple just below it. Fill through the shifter hole if you still have it out or one of the 2 bolts that holds everything down in the tool box. Need a small funnel for this. Fill it with 80/90 till it starts to be visible in the coupling. Put the fill plug back in & giver an extra squirt for the women we go out with and call it good to go. Check after some run in and add as required. Do check the tightness of the hub setscrews if you had the hubs off after some run in. If I recollect right about 1 1/2 quarts?? 1 Share this post Link to post Share on other sites
ebinmaine 79,789 #105 Posted March 11, 2020 Just now, WHX24 said: about 1 1/2 quarts?? Correct for 3 and 4 speeds. 6 and 8 speeds are 2 qts. 1 Share this post Link to post Share on other sites
Psychonova68 36 #106 Posted March 11, 2020 After a little googling I found the manual, 2 Qts. 1 Share this post Link to post Share on other sites
