Southerncannuck 73 #1 Posted February 4, 2020 I have a C125 tractor that I use as a boat tug. It didn’t have an electrical system when I got it. It was easy to rewire it but I skimped on the regulator. I bought a cheap one from amazon and unsurprisingly it quickly failed. Would someone please recommend a source for a quality regulator. Share this post Link to post Share on other sites
Achto 31,314 #2 Posted February 4, 2020 Assuming that you have a Bendix starter. http://www.psep.biz/store/kohler_voltage_regulator.htm If you ever need one for a starter/gen http://www.psep.biz/store/kohler_starter_motors.htm I have had good luck with the parts from this site. 2 1 Share this post Link to post Share on other sites
953 nut 64,660 #3 Posted February 5, 2020 19 hours ago, Southerncannuck said: I bought a cheap one from amazon and unsurprisingly it quickly failed The newer voltage regulators need to be mounted in the fan shroud above the flywheel for cooling. If it is installed with the fins UP rather than down it will not be cooled properly. 1 Share this post Link to post Share on other sites
Southerncannuck 73 #4 Posted February 5, 2020 2 hours ago, 953 nut said: The newer voltage regulators need to be mounted in the fan shroud above the flywheel for cooling. If it is installed with the fins UP rather than down it will not be cooled properly. Thank you. That’s helpful. Share this post Link to post Share on other sites
Searcher60 209 #5 Posted February 6, 2020 On 2/4/2020 at 11:10 AM, Southerncannuck said: I have a C125 tractor that I use as a boat tug. It didn’t have an electrical system when I got it. It was easy to rewire it but I skimped on the regulator. I bought a cheap one from amazon and unsurprisingly it quickly failed. Would someone please recommend a source for a quality regulator. I have an Electro 12 and just purchased a Stens 10 amp regulator off Amazon for like 18.00 shipped with tax. Great regulator, great price. The same regulator sells for up to like hundreds of dollars on other websites. Stens 435-057, came in the orginial Stens box. Stens also makes the 15 amp regulator, it costs even less than the 10 amp. Amazon is a facilitator. They do not manufacture regulators. Who’s regulator did you purchase? Send it back under warranty. Here is the link to the Stens 10 amp on eBay. But, your C125 may have came with the 15 amp, our something else. Sounds sorta like you just slapped a regulator on it. Get correct part number and then find correct regulator. https://www.ebay.com/itm/223796033172?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-213727-13078-0%2F2%3Fmpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F223796033172%26itemid%3D223796033172%26targetid%3D4580840327039647%26device%3Dt%26adtype%3D%26googleloc%3D%26poi%3D%26campaignid%3D301076556%26adgroupid%3D1235851265215130%26rlsatarget%3Dpla-4580840327039647%26abcId%3D1129776%26merchantid%3D51291%26query%3Dstens%2520435-057%26msclkid%3D5b489cd296d41ac3e758c2eeaaabd381%26srcrot%3D711-213727-13078-0%26rvr_id%3D2288556582096%26rvr_ts%3D1b5420a31700a9cc72e5c6cffffe3420 Share this post Link to post Share on other sites
