Stewrun 6 #1 Posted January 31, 2020 Hi All I have the opportunity to get a NOS 3536RL01 mower deck for a great price locally. Would there be any way to use it on my 1989 416-8? Thanks! Share this post Link to post Share on other sites
stevasaurus 23,458 #2 Posted January 31, 2020 I think the fast answer is No. Go to the Manual Section/Implement Manuals/Mower Decks and do a search for 35-36RL01 . The manual and some posts show up...including this thread. It appears that deck is designed to fit the "vertical shaft" 211's...not the "horizontal shaft" horses. Sorry. Type is search just the way I show it above. Share this post Link to post Share on other sites
Stepney 2,354 #3 Posted January 31, 2020 I think I may know the deck your speaking of. If its anything like older vertical shaft decks, the holes are all there. Just cut off the brackets, bolt on yours, and change out the pulleys. I have two 42"RD vertical decks converted to TAM use. Share this post Link to post Share on other sites
daveoman1966 3,880 #4 Posted January 31, 2020 You'll only need to attach a few brackets to adapt the 35-36RL01 deck to your tractor...that includes to trim off the front anti-scalp roller bracket...MAYBE NOT.. The deck shell is (usually) pre-drilled to accept hardware of many styles. IMHO...buy it. Share this post Link to post Share on other sites
Stepney 2,354 #5 Posted January 31, 2020 21 minutes ago, daveoman1966 said: That includes to trim off the front anti-scalp roller bracket...MAYBE NOT.. In my finding you usually just have to cut some material off the top with these decks, the rest can remain. Only stragglers I've ever seen were the rear engine variety. Share this post Link to post Share on other sites
