Rickenbacker53 0 #1 Posted January 27, 2020 Is there a good Website where I can buy Replacement Belt for Toro 264 Garden Tractor : I thought I had a Cross Reference File but can't find it : Any ideas are appreciated Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted January 27, 2020 Check the manual section for the part number and then l would check ebay or your local napa to Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #3 Posted January 27, 2020 Your model number is 72043. I'm guessing the model year but likely all the same. This model produced 1994, 1995 and 1996 determined by tractor serial number. The belt numbers and dimensions have been added to this page. Click on the picture. Hydro transmission drive belt 92-6718 replaced by 92-6954 (HA x 88.25" or 1/2" x 88.25") Make sure you get a belt designed to bend backwards over a flat idler. Garry Share this post Link to post Share on other sites
Rickenbacker53 0 #4 Posted January 27, 2020 Tried that No luck I have the Tractor model as well as the OEM belt number Share this post Link to post Share on other sites
WHX?? 54,977 #5 Posted January 29, 2020 https://www.vbelts4less.com/A-A86K-Kevlar-Replacement-V-Belt-For-Toro-Wheel-Horse-Belt-92-6954_p_164057.html or if you want to stay with OEM https://www.amazon.com/Toro-V-belt-Hydro-Part-92-6954/dp/B00TD91LSY Share this post Link to post Share on other sites
