wildman 205 #76 Posted February 2, 2020 Original air cleaner for your machine would have been oil bath which is smaller diameter and as tall 1 Share this post Link to post Share on other sites
Oldskool 6,663 #77 Posted February 2, 2020 A 1" washer and a 90 degree pipe elbow. I just had to dig a bit deeper in my stock pile 1 Share this post Link to post Share on other sites
Oldskool 6,663 #78 Posted February 2, 2020 Don't know what this came off of but it will do. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #79 Posted February 2, 2020 The list is getting alot shorter 4 1 Share this post Link to post Share on other sites
ebinmaine 72,668 #80 Posted February 2, 2020 Well there you go!! 1 Share this post Link to post Share on other sites
wildman 205 #81 Posted February 2, 2020 (edited) 1 hour ago, Oldskool said: Don't know what this came off of but it will do. That would be an air cleaner assembly off of a Tecumseh horizontal engine Edited February 2, 2020 by wildman 1 Share this post Link to post Share on other sites
Stormin 9,984 #82 Posted February 3, 2020 Just the job. 1 Share this post Link to post Share on other sites
tractornut86 621 #83 Posted February 4, 2020 To tell the model of this you gotta take look st the engine mounts. The S18 had a 8hp Kohler where the one engine bolt sat over top the frame rail and the S19 had a 8hp Briggs that if your engine bolted directly down then it was original S19. If you are interested in fenders I have nos S23/S24 fenders that is same as the smaller fenders except just larger and you would have to make center peice bracket. I also have original engine pulley, hood hinges and maybe a belt guard if want to put it to original. Share this post Link to post Share on other sites
Oldskool 6,663 #84 Posted February 5, 2020 19 hours ago, tractornut86 said: . The S18 had a 8hp Kohler where the one engine bolt sat over top the frame rail and the S19 had a 8hp Briggs that if your engine bolted directly down then it was original S19. i would say mine is the S18 model. A far as the parts go, I will be thinking it over for sure. Thanks @tractornut86 Share this post Link to post Share on other sites
Oldskool 6,663 #85 Posted February 9, 2020 Started the tear down yesterday. It's in the minus digits this morning so garage work is low starting today. Hope to have the engine done today. 1 Share this post Link to post Share on other sites
ebinmaine 72,668 #86 Posted February 9, 2020 14 minutes ago, Oldskool said: Started the tear down yesterday. It's in the minus digits this morning so garage work is low starting today. Hope to have the engine done today. - 10 here this morning. Bit chilly for work in an unheated space... Share this post Link to post Share on other sites
ebinmaine 72,668 #87 Posted February 9, 2020 15 minutes ago, Oldskool said: have the engine done Repaint and clean up? Share this post Link to post Share on other sites
Oldskool 6,663 #88 Posted February 9, 2020 2 minutes ago, ebinmaine said: - 10 here this morning. Bit chilly for work in an unheated space... -5 here. I have heat but will take a bit to warm up. Didn't leave heat on in there last night 1 Share this post Link to post Share on other sites
Oldskool 6,663 #89 Posted February 9, 2020 4 minutes ago, ebinmaine said: Repaint and clean up? Yup clean and paint the whole thing 1 Share this post Link to post Share on other sites
Oldskool 6,663 #90 Posted February 9, 2020 Letting the ole oven cleaner do its thing. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #91 Posted February 9, 2020 Well the black is no more. Looks alot better in NAPA I.H. Red 3 1 Share this post Link to post Share on other sites
ebinmaine 72,668 #92 Posted February 9, 2020 Oooooooooooo Aaaahhhhhhhh 1 Share this post Link to post Share on other sites
Stormin 9,984 #93 Posted February 9, 2020 Paint the rest of the engine black and the job will be a good un. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #94 Posted February 9, 2020 There is a bump stop under the tie rod in the area of the green circle. There isn't in the red circle. Is there supposed to be? Turn one direction it hits the stop. Turn the other and the steering seems to cam over itself, but not to the point it locks itself in place. Share this post Link to post Share on other sites
Oldskool 6,663 #95 Posted February 9, 2020 1 hour ago, Stormin said: Paint the rest of the engine black and the job will be a good un. Wouldn't painting the aluminum hold in the heat? Share this post Link to post Share on other sites
ebinmaine 72,668 #96 Posted February 10, 2020 15 minutes ago, Oldskool said: Wouldn't painting the aluminum hold in the heat? Technically yes. That's true. I've seen discussions that showed it doesn't much matter on an air cooled engine unless maybe it's running an implement or machinery. The Briggs on Trina's 867 is painted. Seems fine. She uses it to pull a wood trailer around but no "working" it. Share this post Link to post Share on other sites
Oldskool 6,663 #97 Posted February 10, 2020 16 minutes ago, ebinmaine said: Technically yes. That's true. I've seen discussions that showed it doesn't much matter on an air cooled engine unless maybe it's running an implement or machinery. The Briggs on Trina's 867 is painted. Seems fine. She uses it to pull a wood trailer around but no "working" it. Now I'm wondering if I should dismantle again and paint the exposed aluminum. If so, black or red? Decisions decisions. Dang it 1 Share this post Link to post Share on other sites
ebinmaine 72,668 #98 Posted February 10, 2020 12 minutes ago, Oldskool said: Now I'm wondering if I should dismantle again and paint the exposed aluminum. If so, black or red? Decisions decisions. Dang it I like the contrast it has right now. I'd also like the contrast of the black.... What color will the tractor be? Share this post Link to post Share on other sites
Oldskool 6,663 #99 Posted February 10, 2020 2 minutes ago, ebinmaine said: What color will the tractor be? Stock -ish paint scheme. Same red as the engine with yellow wheels and seat. Share this post Link to post Share on other sites
Oldskool 6,663 #100 Posted February 10, 2020 More or less like this one 2 Share this post Link to post Share on other sites
