tom2p 2,396 #26 Posted January 14, 2020 (edited) 2 hours ago, 1988SS said: Pis of the WH I hope to get. Will it be difficult to match the color of the paint? I know reds fade over time. 86 Monte SS, mostly stock, 305, 200r4orig paint...hundreds of hours were put into the car to make it look like nothing was done.. It's not fast but makes all the right sounds. good looking monte carlo ss ... the old nascar monte ... tractor looks very good - 314-8 with Kohler Magnum ? if so - this would be one of the most desirable WH tractors avail for home use / medium size yard ( and even better with a desirable 48" deck ) very few tractors would match the performance, versatility, reliability durable as an anvil - require little more than basic maintenance - and will provide years and years of service easy to work on - install / remove attachments including mower deck and snow plow (w/no tools) - and items including belts are also fairly easy to replace (and if quality belts are used they will provide years of service before replacement required) Edited January 14, 2020 by tom2p 3 Share this post Link to post Share on other sites
clueless 3,440 #27 Posted January 14, 2020 314-8 Wheel Horse with a 14 hp magnum, snowblower, 48 inch deck, that other than a little road rash looks to be in good condition for $800 . You ain't gonna get nothing like that for no $2000 . DO IT! 2 Share this post Link to post Share on other sites
AHS 1,703 #28 Posted January 14, 2020 The 14hp will turn that snowblower easy! That’ll turn a 42” to 48” deck. 14hp kohler is a Cadillac of a motor. My dad is running a 79 wheel horse 10hp kohler...and she still going! Share this post Link to post Share on other sites
Goofey 89 #29 Posted January 14, 2020 (edited) Is it just me or ain't there something missing here. I do not see no info on what the tasks are that it should handle. How big a lawn? Thick high grass or? Much snow? other tasks like tilling or plowing or? Also a 48" is a tall order for a 14 hp engine no matter what you guys say. More so when it is a manual 8 speed. My crystal ball shows me a guy on a 314-8 mowing along in 3rd gear. 4 mph or so full slow speed. Because it simply cant handle a 48" in 4th. That's just how I see it. Not trying to offend no one. Edited January 14, 2020 by Goofey Have to keep my open mouth in check and be more diplomatic 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,824 #30 Posted January 14, 2020 44 minutes ago, Goofey said: Also a 48" is a tall order for a 14 hp engine no matter what you guys say. Been there done that. OK Goof, If all those 14M Kohlers of yours failed to turn your 48" decks, You either had worn out engines, decks, or were trying to cut 10" grass in a high gear. I have a 48" SD on a C-120H, a 312H and a 417H. I normally use the 12 HP mowers as they run cooler. If I get lazy and miss a regular mowing, then I may use the 417. BTW, I have successfully used SS blowers on both of the 12s. Note these are all hydros that have less HP available at the PTO than a gear drive. So, to use your statement "no matter what you say" IMO, the 314-8 with a 48" deck and SS blower will be a great working machine. 4 2 Share this post Link to post Share on other sites
Goofey 89 #31 Posted January 14, 2020 I would think the hydro part of it is why. You can adjust speed to match the power you have much better. But go ahead and be mad at me for saying it as I see it. Share this post Link to post Share on other sites
pfrederi 21,312 #32 Posted January 14, 2020 1 hour ago, Goofey said: Is it just me or ain't there something missing here. I do not see no info on what the tasks are that it should handle. How big a lawn? Thick high grass or? Much snow? other tasks like tilling or plowing or? Also a 48" is a tall order for a 14 hp engine no matter what you guys say. More so when it is a manual 8 speed. My crystal ball shows me a guy on a 314-8 mowing along in 3rd gear. 4 mph or so full slow speed. Because it simply cant handle a 48" in 4th. That's just how I see it. Not trying to offend no one. If you have 4th gear in a WH you have a very special unit... 3 1 1 Share this post Link to post Share on other sites
Bigtrx34 321 #33 Posted January 14, 2020 As many others have stated you cant go wrong with the horse. From a money standpoint those attachments for the "green ones" will be 3 times what you could get a used wheel horse for. Even more if it is a hydro unit. A used snowblower hydro for my buddies green tractor was over 1100 in well used condition. I love my 312-8 and 520 they work year round from grass to snow and everything between. From a maintenance stand point wheel horses are tuff as nails. They are simple to work on if needed but don't require much more than oil changes and a good grease gun. I am not bashing any other brand, you need to get what works best for you, your wallet, and your property. For me its the horse. Best of luck and welcome 1 1 Share this post Link to post Share on other sites
WHX?? 58,347 #34 Posted January 14, 2020 This little piece of attachment list says not only will a 314 handle a 48 but a 312 will too. Knowing my Kohlers I wouldn't be afraid to hook one up to a 310! 4 Share this post Link to post Share on other sites
SylvanLakeWH 32,823 #35 Posted January 14, 2020 Don’t want to get off topic, but Curious...Isn’t this a question of where you send the power? By that I mean gearing down (slower speed) gives more power to the PTO...While gearing up (faster) leaves less power to the PTO... Correct? Regardless of HP... I have cut 3’ tall “grass” on a neglected vacant lot with my 10 hp C 105 8 speed side discharge and as long as I was going in the low range gears it cut like a hot knife through butter...initial cut wasn’t pretty but with a follow up cut at regular speed / height it looked quite good... Don’t own a hydro, so also curious if they “take” more or less power relative to speed the same way gears do? 2 Share this post Link to post Share on other sites
JCM 11,451 #36 Posted January 14, 2020 WH 312-8 with a 48'' SD mower and bagger with 5 hp briggs. 1 Share this post Link to post Share on other sites
Ed Kennell 47,824 #37 Posted January 14, 2020 2 minutes ago, SylvanLakeWH said: Don’t own a hydro, so also curious if they “take” more or less power relative to speed the same way gears do? Without question Jim, the hydros require more HP than a gear drive. I have seen some estimates but I don't recall the exact numbers. 1-2 HP seems to be what the hydros need. This is clear when you engage the hydro. Depending on the temperature of the oil, you will see a significant drop in engine RPM. And this is with the motion control in neutral. 1 Share this post Link to post Share on other sites
ebinmaine 81,150 #38 Posted January 14, 2020 25 minutes ago, SylvanLakeWH said: a hydro, so also curious if they “take” more or less power relative to speed the same way gears do? 15 minutes ago, Ed Kennell said: Without question Jim, the hydros require more HP than a gear drive. I haven't the foggiest where I came up with these numbers. May have been my local Small engine guy. Gear drive Wheelhorse uses about .5 - 1 HP to move the tractor on flat ground at full speed. Same tractor with a hydro is about 2 - 2.5 horsepower. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #39 Posted January 14, 2020 I have both a 315-8 with a 48" deck and 520H with 48" deck under normal grass cutting conditions you can't tell the difference but tall wet green grass my 20hp opposed twin hydro will out cut the single cylinder Kohler and I'm sure the same goes with snow and the single stage throwers. But then again I have a 3 cylinder diesel now for most of my grass cutting. 4 Share this post Link to post Share on other sites
chip61 666 #40 Posted January 15, 2020 You can't go wrong with that 314-8. I killed a box store mower (I didn't buy it, my father in law did) in a few short years but the Wheel Horse just keeps coming back for more! 5 Share this post Link to post Share on other sites
adsm08 5,243 #41 Posted January 15, 2020 5 hours ago, Goofey said: Is it just me or ain't there something missing here. I do not see no info on what the tasks are that it should handle. How big a lawn? Thick high grass or? Much snow? other tasks like tilling or plowing or? Also a 48" is a tall order for a 14 hp engine no matter what you guys say. More so when it is a manual 8 speed. My crystal ball shows me a guy on a 314-8 mowing along in 3rd gear. 4 mph or so full slow speed. Because it simply cant handle a 48" in 4th. That's just how I see it. Not trying to offend no one. I have two things to say about this: 1) Out of all the WH tractors I have ever seen I have never seen one with a 4th gear. 2) All the WH tractors I have had were manual transmission, and no matter how big the yard I could never effectively corner the mower in anything above 2nd. Some stretches on my parents yard were long enough that it was worth shifting up the 3rd for them, but my yard has so many twists and turns I spend more time shifting back and forth to make corners than I do just mowing in 2nd. 1 Share this post Link to post Share on other sites
Jerry.Guzzi 6 #42 Posted January 15, 2020 My 520-H doesn't like tall grass at a slow speed. Just saying. I would like to know the timing of blades. Share this post Link to post Share on other sites
ZXT 2,402 #43 Posted January 15, 2020 (edited) On 1/14/2020 at 2:06 PM, Goofey said: Also a 48" is a tall order for a 14 hp engine no matter what you guys say. Oh wow! Thanks for your intelligent observation - and for denouncing every opinion but your own! Again, thank you for schooling us and telling us how it is. What's next on your list? Telling us that a 10-12HP Horse can't handle a 42" deck? It's a wonder that anyone on here has ever successfully mowed their lawn! Edited January 15, 2020 by ZXT 2 Share this post Link to post Share on other sites
tom2p 2,396 #44 Posted January 15, 2020 2 hours ago, Jerry.Guzzi said: My 520-H doesn't like tall grass at a slow speed. Just saying. I would like to know the timing of blades. not sure I understand your observation - slow ground speed or slow engine speed ? 520-H should have more than enough power to cut tall grass - with 42" - 60" mower decks - provided engine speed is appropriate and tractor / mower deck is in proper operating condition including PTO, belts (good condition and properly tensioned) and correct sharp mower blades 1 Share this post Link to post Share on other sites
tom2p 2,396 #45 Posted January 15, 2020 (edited) 6 hours ago, ebinmaine said: I haven't the foggiest where I came up with these numbers. May have been my local Small engine guy. Gear drive Wheelhorse uses about .5 - 1 HP to move the tractor on flat ground at full speed. Same tractor with a hydro is about 2 - 2.5 horsepower. number I was given at one time is 10% ; hydro 10% less efficient ... but this can vary because there are many variables ; manual transmissions vary as do the hydro transmissions ... number of gears / shafts involved ... variable vs fixed displacement pump ... etc etc ... the engine characteristics might also come into play when i think of power transmission and efficiency or loss etc - sprint cars quickly come to mind ... no clutch / no transmission ... direct drive ... it's in - or out ... Edited January 15, 2020 by tom2p Share this post Link to post Share on other sites
1988SS 50 #46 Posted January 15, 2020 Picked her up tonight on my, new to me, 16' car hauler..pics tomorrow. Talked the seller down for minor issues.1) throttle lever loose, 2) old tires 3) parking brake not working 4)seat interlock bypassed 5) play in steering - thank you forum members for your great advice. The future plans, as with all my projects, is to restore/refurb/clean up to close to new condition and to cherish this well loved classic. In case you did not catch this - I love my, made in between the Atlantic and Pacific Oceans, analog technology! 3 6 Share this post Link to post Share on other sites
lynnmor 9,073 #47 Posted January 15, 2020 6 hours ago, Jerry.Guzzi said: My 520-H doesn't like tall grass at a slow speed. Just saying. I would like to know the timing of blades. Run the engine at full speed, use blades that are not worn out and correctly sharpened and there is no such thing as "timing of blades" on a 520H. 2 Share this post Link to post Share on other sites
ebinmaine 81,150 #48 Posted January 15, 2020 3 hours ago, 1988SS said: . In case you did not catch this - I love my, made in between the Atlantic and Pacific Oceans, analog technology Right There with you!! Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #49 Posted January 15, 2020 8 hours ago, Jerry.Guzzi said: My 520-H doesn't like tall grass at a slow speed. Just saying. I would like to know the timing of blades. When I encountered tall (above 8") grass I lift the deck ALL the way up to the tractor frame (transport mode) Then mow then repeat on the highest setting on the gauge wheels and so on until I get the desired height... You just can't go at it even with brand new sharp blades with the deck down JMO and experiences. 3 Share this post Link to post Share on other sites
953 nut 70,347 #50 Posted January 15, 2020 15 hours ago, Goofey said: Also a 48" is a tall order for a 14 hp engine The first 48" deck that Wheel Horse produced was in 1963 and was on a 953 which has a 9.6 HP Kohler. I have mowed a bunch of grass with that set up and had no problems. If your 14 HP won't handle a 48" deck it may be time to sharpen the blades or give the engine a tune-up. 3 Share this post Link to post Share on other sites
