Rickenbacker53 0 #1 Posted January 10, 2020 Tractor starts fine. Using it to blow snow. Once the thing gets wet from teh snow and turned off It won't restart : Let it set overnight and it fires right up. I've cleaned all connections and purchased a OEM Starter solenoid : Apparently this wasn't needed : SO is it possible it's the starter Switch ? Back ground to my thinking . Last season Several times The Ignition was frozen . After Thawed out I could get the Tractor to start. Is it possible it's the Brake Safety ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #2 Posted January 10, 2020 You need to check it when it won't start to see what is working and what is not. Garry Share this post Link to post Share on other sites
