Countdown To Christmas!
redone
Kohler 301 head bolts
redone
I am searching for two sets of head bolts for k series kohler. 301
Thanks
Bill
ebinmaine
Others might be able to chime in with sizes here or you could check the manual but I think they're just regular grade 8 bolts.
To the best of my knowledge there not a stretch to yield type modern head bolt.
pacer
As Eric sez -- I just go to the bolt store (usually TSC) and grab a handful of grade 8's. And of course I come home with a mix of 8's and of course another handful of misc grad 5's ---- and .... generally a couple another item or 2! :razz:
pfrederi
Bolts is bolts but Kohler uses a thick washer.  which they sell for over $5 each.  they are about .115" thick
The Tuul Crib
Are the washers hardened steel as well?
pfrederi
No idea...Pulling against and aluminum head you would not think so but who knows.:unsure:
oldredrider
To test hardness, take a triangle file to it. If it files easy, not hardened.
pfrederi
I will give that a try tomorrow  great idea  I am not a metallurgist.
redone
Hi Guys. I appreciate all feed backs. I like the original parts to make my engines like factory. Resurface heads and block.to new crank bearings. Kohler head gaskets. Bead blast block. Only paint the lower end of block. All shrouds sand blasted primed and painted in factory color.
Nothing but the best..
pfrederi
Based on the "file" test they are not hardened...  Why they are over $5 each ...no clue.
The Tuul Crib
Maybe because they are so thick?
