BenHolcomb 332 #101 Posted May 13, 2020 Appreciate the encouragement we're in the home stretch now. Hopefully picking up the remainder of the painted parts tomorrow. Still to do is install the starter generator, pans, guards, hood, pulleys, belts, torque the head and fire her up! Oh and stickers. Can't forget them. Side note: I plan to continue running this on AV gas. I can't get non-ethanol around me but 100LL is easily acquired and the price isn't bad. With that in mind I bought several feet of superflex aviation 1/4 fuel line. Little mod to keep it from breaking down the rubber as this stuff is safe for most everything. Share this post Link to post Share on other sites
ebinmaine 75,777 #102 Posted May 13, 2020 15 minutes ago, BenHolcomb said: AV gas Is avgas aviation and hence non E...? Share this post Link to post Share on other sites
BenHolcomb 332 #103 Posted May 14, 2020 46 minutes ago, ebinmaine said: Is avgas aviation and hence non E...? Correct LL stands for low lead in the 98~100 octane range I believe. Non-ethanol and most old engines love it. As do several air-cooled vintage motorcycles we run. I dont run it in the tractor for any performance reason although I do believe it burns cooler and in theory would lubricate better containing Lead...but the shelf life is great so I don't need to drain anything. There's a small airport near me that sells it, so it gets used in all my power equipment. 1 Share this post Link to post Share on other sites
ebinmaine 75,777 #104 Posted May 14, 2020 7 minutes ago, BenHolcomb said: Correct LL stands for low lead in the 98~100 octane range I believe. Non-ethanol and most old engines love it. As do several air-cooled vintage motorcycles we run. I dont run it in the tractor for any performance reason although I do believe it burns cooler and in theory would lubricate better containing Lead...but the shelf life is great so I don't need to drain anything. There's a small airport near me that sells it, so it gets used in all my power equipment. Here in Maine most airports have 108 and most airports also won't sell it unless you have a tail number from your plane. A few places do sell to anyone with proper gas can but $$$$$.... WOW. I'm VERY lucky... I have a station just over the border in NH that's sells non E. 1 Share this post Link to post Share on other sites
BenHolcomb 332 #105 Posted May 14, 2020 I haven't checked the price lately since the OPEC troubles. Typically it's a $1-2 more than high test which seems like a lot...but it's a fraction of what those little cans of premix cost that all my echo tools use. Nor do I want to mess with stabilizer or rebuilding ity-bity carbs when ethanol inevitably ruins them. The pump does require a tail number so I usually pick a random warbird just to irritate and confuse big brother. (Inspector) Why did a B-29 land at New garden and only buy 5 gallons? 1 4 1 Share this post Link to post Share on other sites
BenHolcomb 332 #106 Posted May 15, 2020 How about a few pictures from yesterday's progress? She's a runner! With a noticeable seat of the pants difference in power after the rebuild. In fact her maiden first few feet was a second gear wheelie! I slipped on the bare seat pan dumping the clutch. 2 8 3 Share this post Link to post Share on other sites
WHX?? 53,356 #108 Posted May 15, 2020 That is just beuuuutiiiiful Ben! Once you get a seat on her make sure that fender pan is latched. Those little can make that pan flip up! 4 Share this post Link to post Share on other sites
BenHolcomb 332 #109 Posted May 15, 2020 Hope to be mowing with it this weekend if I can finish the seat. As far as engine break in goes consensus seems to be all over the place..so I'm warming it up then varying the rpms in different gears and will do another oil change after an hour or so. My grandfather who originally owned the tractor suggested I get another to actually beat on because this has turned out too nice. 2 1 Share this post Link to post Share on other sites
tom2p 2,394 #110 Posted May 15, 2020 outstanding job !!! 1 Share this post Link to post Share on other sites
WHX?? 53,356 #111 Posted May 15, 2020 Just remember one thing … Grampas are always right! Best way to break in is full throttle and under a load! Get them rings to seat. 2 1 Share this post Link to post Share on other sites
BenHolcomb 332 #112 Posted May 15, 2020 2 minutes ago, WHX24 said: Just remember one thing … Grampas are always right! Best way to break in is full throttle and under a load! Get them rings to seat. Makes sense! The only hesitancy I have is I don't have a way of checking max rpms are correct.. although the governor and throttle are set as they were. Plan to purchase the doohicky that reads single cylinder rpms. 1 Share this post Link to post Share on other sites
WHX?? 53,356 #113 Posted May 15, 2020 13 minutes ago, BenHolcomb said: doohicky that reads single cylinder rpms. Always a good tool to have. The max rpm is adjusted by the lever behind the governor nut that the cable attaches to. In the Kohler manual in case you need to reference it. 1 Share this post Link to post Share on other sites
R. L. Addison 299 #114 Posted May 15, 2020 I've got a couple engines I have put rings in (overhaul) and put the oil that I regularly run in, and the rings don't appear to be seating, so I will put in a non-detergent oil and run them for a while then put in my regular oil like we had to do to some of the cars in the late '50's and early '60,s. (At engineering recommendations). 1 Share this post Link to post Share on other sites
Racinbob 12,431 #115 Posted May 15, 2020 1 hour ago, WHX24 said: That is just beuuuutiiiiful Ben! Once you get a seat on her make sure that fender pan is latched. Those little can make that pan flip up! My 500 Special has the same fender latch. I spring loaded it underneath to the latched position. Incredible job Ben!! 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,872 #116 Posted May 15, 2020 Beautiful! 1 Share this post Link to post Share on other sites
BenHolcomb 332 #117 Posted May 15, 2020 Thanks for the nice comments fellas, the latch spring is a good idea. Mine fits tight as is probably because of paint build up...but ill keep that in mind if it becomes an issue. 1 Share this post Link to post Share on other sites
BenHolcomb 332 #118 Posted May 15, 2020 The final piece will be ready for pick up tomorrow. Everyone wants a ride! 2 6 1 4 Share this post Link to post Share on other sites
RandyLittrell 3,942 #119 Posted May 16, 2020 Really nice job, looks dang good!! Randy 1 Share this post Link to post Share on other sites
BenHolcomb 332 #120 Posted May 17, 2020 Finished. It'll never be this clean again! 2 11 1 Share this post Link to post Share on other sites
BenHolcomb 332 #121 Posted May 17, 2020 Post mowing report. It runs like a top. The only failure was the new brake band fell off. Silicone rtv didn't hold so I'll be trying automotive epoxy next. 3 4 Share this post Link to post Share on other sites
Mikey the Monkey 701 #122 Posted May 17, 2020 Beautiful. Hopefully stays in your family for generations to come 1 Share this post Link to post Share on other sites
chex313 123 #124 Posted May 19, 2020 Gotta figure the babe is more comfortable with the horse then the scary dog. What a face, adorable 1 Share this post Link to post Share on other sites
Tractorhead 9,215 #125 Posted May 19, 2020 She‘s a real Beauty 1 Share this post Link to post Share on other sites
