bigbore1934 3 #1 Posted December 30, 2019 So my fuel pump on my 1975 B-80 is leaking like a siv...I've tightened it as much as I could multiple times to get the mowing season finished, but now it's time to fix as it's leaking worse than ever! Do I fix or replace? It has the original cast aluminum pump. I've seen the plastic replacements online that are fairly cheap. Is there someplace that sells the diaphragm so I could fix the existing pump? Which is best? Thanks for any info! Share this post Link to post Share on other sites
ebinmaine 75,845 #2 Posted December 30, 2019 There's a place in Massachusetts called Thenandnowautomotive.com That sells rebuild kits for your original aluminum pump for around $30. I've not bought one personally yet but I've never heard a bad word about them. I'd go that way if I needed a pump. 2 Share this post Link to post Share on other sites
Achto 30,219 #3 Posted December 30, 2019 They are the only supplier of Kohler fuel pump kits that I know of. http://www.then-now-auto.com/kohler-fuel-pumps-2/ 2 Share this post Link to post Share on other sites
WHX?? 53,388 #4 Posted December 30, 2019 While your in there consider new filter & fuel lines. The ethanol in regular gas eats away at the rubber & pump diaphragms so consider running unlaced gas if available in your area. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted December 30, 2019 to of that B80!! 1 Share this post Link to post Share on other sites
953 nut 63,136 #6 Posted December 30, 2019 When a Kohler fuel pump leaks it is very likely that some of the gas has gotten into your engine oil also. be sure to change the oi. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #7 Posted December 30, 2019 51 minutes ago, 953 nut said: When a Kohler fuel pump leaks it is very likely that some of the gas has gotten into your engine oil also. be sure to change the oi. 1 Share this post Link to post Share on other sites
Tach-a-matic 357 #8 Posted December 30, 2019 (edited) I got tired of looking for the proper replacement so just bypassed it on my B-80. The tank is high enough that it does not need a pump, except to get maybe that last 1/8 out of it. It ran fine for the couple of hours I used it last week. Gravity is very reliable Edited December 30, 2019 by Tach-a-matic Share this post Link to post Share on other sites
ebinmaine 75,845 #9 Posted December 30, 2019 13 minutes ago, Tach-a-matic said: I got tired of looking for the proper replacement so just bypassed it on my B-80. The tank is high enough that it does not need a pump, except to get maybe that last 1/8 out of it. It ran fine for the couple of hours I used it last week. Gravity is very reliable That's true as long as you are on level ground or pointed nose down a bit. I couldn't get away with that here on the mountainside. 1 Share this post Link to post Share on other sites
bigbore1934 3 #10 Posted December 31, 2019 Thanks guys! I will check that site out as soon as I get the c old one off,as I see I need to know what style it is. 2 Share this post Link to post Share on other sites
tntatro 181 #11 Posted April 5, 2020 Isavetractors also sells the diaphragm pump with spring for Kohler metal fuel pumps. I'm searching for information on a fuel pump that leaks oil out of the pin. The pin was partially pushed out on one side so I tapped it back but it still leaks. I was thinking about putting JB marine weld over the leaking area unless there is a better fix. Share this post Link to post Share on other sites
