Kevinm 23 #1 Posted December 26, 2019 I have a 1989 520H. The 1991 wiring diagram I have shows relays. Some people have indicated that they are under the battery tray. There are none under mine. They only relay I found was next to the starter. I also found all the safe switches, but no kill relay. Is the 1989 wiring diagram different? I am diagnosing the starter circuit, as the relay clicks, but the starter does not turn. I checked all the safety's, and cleaned the 9 pin connector. It worked for a while, and now it will not start. Any help would be appreciated. I also plan to install a new key switch and a starter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #2 Posted December 26, 2019 Garry Share this post Link to post Share on other sites
Kevinm 23 #3 Posted December 26, 2019 Thanks for the fast response!! Share this post Link to post Share on other sites
biged77 113 #4 Posted December 27, 2019 Before changing any parts I would check the battery voltage. Should be 12.5V or higher. Also clean the battery and solenoid connections including the battery ground. You can rule out the starter by hooking a jumper cable from the battery plus to the starter, just make sure the tractor is in neutral and the PTO is disengaged. Ed Share this post Link to post Share on other sites
Kevinm 23 #5 Posted December 27, 2019 Thanks, I went over every connection on the machine and cleaned and tested all the safety switches and coated the connections with dielectric grease. The battery is good and, I keep it on a battery tender. I think the only thing left s a dead spot on the starter. The correct wiring diagram will also help. I was going a little crazy working with the later model diagram, as it is not the same, Thanks again. Share this post Link to post Share on other sites
biged77 113 #6 Posted December 28, 2019 Looks like you have done all the right things so far. You are fortunate to have a 520H model with a simple electrical system, no extra relays. The likely culprits are the solenoid or starter since you hear a clicking sound, indicating the rest of the circuitry is working as it should {solenoid is getting an actuate signal). Ed Share this post Link to post Share on other sites
Kevinm 23 #7 Posted December 28, 2019 Thanks. the troubleshooting forced me to go over the entire electrical system. Share this post Link to post Share on other sites
cleat 7,383 #8 Posted December 28, 2019 Here are the 2 wire diagrams both early and later. I have converted all of mine to the early style for simplicity, reliability, and for the fact that in the end they both do the exact same thing. I do not see why all the extra relays were added or why they decided to put all the charge current through the 9 pin connector. This is the early diagram Wheel horse 520H wire diagram.pdf This is the later diagram Later model 520 wire diagram.pdf Cleat Share this post Link to post Share on other sites
