Travis Evans 1 #1 Posted December 24, 2019 I have a ‘69 Workhorse 700 with the 7hp Tecumseh H70. I think it threw a rod, oil all over the garage floor. Any help with options for repower? Doesn’t look like that motor is readily available... Any help/experience is appreciated. Thanks!! Travis Share this post Link to post Share on other sites
Guest 88vic #2 Posted December 24, 2019 I have the same issue. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted December 24, 2019 2 hours ago, Travis Evans said: I have a ‘69 Workhorse 700 with the 7hp Tecumseh H70. I think it threw a rod, oil all over the garage floor. Any help with options for repower? Doesn’t look like that motor is readily available... Any help/experience is appreciated. Thanks!! Travis Hey Travis couldn't help noticing you're from Lawrence Kansas. I spent a lot of time there when I worked traveling and playing music with Red Foley's grandson! Sorry to hear you're having problems with the Tecumseh but I'm not a real Big fan of the Tecumseh motors. I have two or three K181 s laying around the shop that might work on your tractor. PM me back when you get a chance! Share this post Link to post Share on other sites
Travis Evans 1 #4 Posted December 24, 2019 I guess I haven’t been on here since I lived in Lawrence. I live in Fort Collins, CO now but happen to be back in Lawrence today and tomorrow for the holiday. Where are you located with those Kohler engines? Would like to change over to a Kohler if I can. Not sure what fits. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #5 Posted December 24, 2019 (edited) 25 minutes ago, Travis Evans said: I guess I haven’t been on here since I lived in Lawrence. I live in Fort Collins, CO now but happen to be back in Lawrence today and tomorrow for the holiday. Where are you located with those Kohler engines? Would like to change over to a Kohler if I can. Not sure what fits. Im in Nashville Tn and any one of these should bolt right up.Might have to check on the drive pulley.You might be able to use yours. What you have now is the base plate part number 4416 you could eliminate and just bolt the K1 81 to the frame. Edited December 24, 2019 by The Tool Crib Share this post Link to post Share on other sites
Travis Evans 1 #6 Posted December 25, 2019 Sounds like you've done this a few times. I was wondering if a K161 or K181 would fit without too much trouble. Could be tough to find one where I'm at, but we'll see. Thank you!! Share this post Link to post Share on other sites
richmondred01 2,393 #7 Posted December 25, 2019 (edited) I’ve got a complete h60 block with valves, rod, piston and good cylinder. PM me if interested Edited December 25, 2019 by richmondred01 Share this post Link to post Share on other sites
richmondred01 2,393 #8 Posted December 25, 2019 (edited) I Edited December 25, 2019 by richmondred01 Share this post Link to post Share on other sites
Pullstart 71,516 #9 Posted December 26, 2019 Hey Travis, The Kohler swap in that era is fairly straight forward. On my “Putt Putt” build, it had already been swapped partially to a K-161. I now have a K-181 on it that came from a gas powered portable air compressor. I picked it up cheap because one of the tanks were rusted out. Keep your eyes open for an old walk behind tiller, snow blower, compressor, or other small garden tractors for that matter. Sometimes finding a machine in dispare is cheaper than buying an engine! Merry Christmas Share this post Link to post Share on other sites
Gordyhogg 150 #10 Posted January 1, 2020 Im working on repowering a 656 right now it had a tecumseh 6 horse with a broken rod. Heres a link to my thread if it helps im putting a kohler k181 in it with regular electric start instead of starter generator Share this post Link to post Share on other sites
Goofey 89 #11 Posted January 6, 2020 How about one of the diesel 1 cylinder that skipper sell? I am just about to pull the trigger on a twin. Share this post Link to post Share on other sites
