Xearl 132 #1 Posted December 20, 2019 Can you take out the headlight assembly without taking the hood off ? I bought new led bulbs but the inside of the light housing is pretty bad so I thought I would clean it up and maybe use some chrome spray help . Ed Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted December 20, 2019 Looks like all the pieces are separate and should come apart. https://www.partstree.com/models/73471-518-xi-toro-garden-tractor-sn-000000001-000999999-2000/hood-headlight-assembly-35/ Garry Share this post Link to post Share on other sites
Xearl 132 #3 Posted December 21, 2019 4 hours ago, gwest_ca said: Looks like all the pieces are separate and should come apart. https://www.partstree.com/models/73471-518-xi-toro-garden-tractor-sn-000000001-000999999-2000/hood-headlight-assembly-35/ Garry Gary , Thanks for the post . I looked for that but couldn't find that picture . Looking at it again I think there are four screws that hold the light in . I'll polish the lens and spray the reflector part . Thanks again . ED Share this post Link to post Share on other sites
new2horses 287 #4 Posted December 21, 2019 Ed, You most likely could , but it is much simpler to take the hood off . just remove the grill open the hood disconnect headlight wire harness and remove the two hood pivot bolts, the remainder will be self explanatory. Note: the hood is fairly heavy! David Share this post Link to post Share on other sites
Xearl 132 #5 Posted December 21, 2019 1 hour ago, new2horses said: Ed, You most likely could , but it is much simpler to take the hood off . just remove the grill open the hood disconnect headlight wire harness and remove the two hood pivot bolts, the remainder will be self explanatory. Note: the hood is fairly heavy! David Thanks David I'll take a second look and make my mind up . Thanks for you interest . ED Share this post Link to post Share on other sites
