quahog 14 #26 Posted April 27, 2020 I suspect you are correct , I just have no idea what's in there ! Time to refresh ! I do use 140 GL 4 in an older race car as it is safe for bronze and brass internal parts , Modern GL 5 not so. I can find ( GL 4 ) basic 90 wt at NAPA . Sta Lube makes it. Thanks for the quick reply .. Rain heading your way soon ! quahog 1 Share this post Link to post Share on other sites
Stepney 2,354 #27 Posted April 29, 2020 I've got about 7 gallons of 900w Shell Steam oil.. can I use it? HAHAH. Model A's called for a 600wt, lot of guys just use STP stop knock as it's nearly the same thing. As for a WH.. 90wt. That said, what is this issue with the shifting rails? I saw it mentioned, but have never heard of the issue before. I'm about to do a change on my new Raider 10. I noticed the 6 speed has an extension neck on the plug near the hitch. I'll have to get a photo.. should it be filled to the overflow of the actual housing, or to the top of said pipe? Share this post Link to post Share on other sites
ebinmaine 72,145 #28 Posted April 29, 2020 25 minutes ago, Stepney said: I've got about 7 gallons of 900w Shell Steam oil.. can I use it? HAHAH. Model A's called for a 600wt, lot of guys just use STP stop knock as it's nearly the same thing. As for a WH.. 90wt. That said, what is this issue with the shifting rails? I saw it mentioned, but have never heard of the issue before. I'm about to do a change on my new Raider 10. I noticed the 6 speed has an extension neck on the plug near the hitch. I'll have to get a photo.. should it be filled to the overflow of the actual housing, or to the top of said pipe? The extension neck was installed so that oil level would sit higher in a 6 or 8 speed than it does in a 3 or 4 speed. That said, the oil level actually sits just a bit higher than the top of the extension if you put the full two quarts in. I remove the shifter to pour the oil in. 1 Share this post Link to post Share on other sites
Stepney 2,354 #29 Posted April 29, 2020 Tops, I'll see about that. Wasn't sure if it was some later modification or not. 1 Share this post Link to post Share on other sites
ebinmaine 72,145 #30 Posted April 29, 2020 Just now, Stepney said: Tops, I'll see about that. Wasn't sure if it was some later modification or not. No no... Wheelhorse put em there... Share this post Link to post Share on other sites
pfrederi 18,596 #31 Posted April 29, 2020 The extension was to raise the oil level for the 10 pinion differentials. Chargers had the 10 pinion but a hydro carries oil almost to the top of the trans axle. 1 Share this post Link to post Share on other sites
ebinmaine 72,145 #32 Posted April 29, 2020 Just on a side note.... Is there such a thing as Too Much Oil in a manual transmission? Share this post Link to post Share on other sites
pfrederi 18,596 #33 Posted April 29, 2020 1 minute ago, ebinmaine said: Just on a side note.... Is there such a thing as Too Much Oil in a manual transmission? Interesting question...however 3 or 4 qts of GO90 might be a bit stiff for a manual. The hydros were running ATF which is what about 20w??? Share this post Link to post Share on other sites
ebinmaine 72,145 #34 Posted April 29, 2020 Just now, pfrederi said: Interesting question...however 3 or 4 qts of GO90 might be a bit stiff for a manual. The hydros were running ATF which is what about 20w??? 20... Maybe thinner?? Never thought about it..... How's your 40W engine oil compare to the 90W gear oil? Share this post Link to post Share on other sites
pfrederi 18,596 #35 Posted April 29, 2020 40 w has worked in my L107 for 50+ years... 1 Share this post Link to post Share on other sites
WHX?? 51,572 #36 Posted April 29, 2020 (edited) 1 hour ago, Stepney said: That said, what is this issue with the shifting rails? I saw it mentioned, but have never heard of the issue before. In early 60's trannies the shift rails were completely round. It was believed that once in gear shifting out of gear might be difficult or the possibility of grabbing two gears at once. because of the suction effect in the rail hole. When they started recommending 80/90 instead of 40 is when the problem cropped up. 63/64 and anything later they started putting flats on the rails for a return path out of the back side of the rail. This is a '62 three speed set I put the flats on. Edited April 29, 2020 by WHX24 1 1 Share this post Link to post Share on other sites
pfrederi 18,596 #37 Posted April 29, 2020 I have never been in the tranny of my L107 neither have I ever had a problem requiring prying the shift forks back into alignment...and i kinda doubt my father had any issue over the first 25 or so years. And this horse has been used a lot. Wonder why they didn't stick with 40 w. Share this post Link to post Share on other sites
Guest 88vic #38 Posted April 30, 2020 I've been using "00" for awhile now, no issues and the transmissions are shifting easily. I had a noisy worn one in a workhorse 700, changed it out and put "00" in, now quiet, I use it to pull a roller. Wanted to get a used one at the big show, itll have to wait until 2021. Share this post Link to post Share on other sites
Guest 88vic #39 Posted April 30, 2020 I will add that in cold weather I imagine that it wouldn't like it very well but I dont use those ones in winter anyways. My snow pusher has 80w90 in it. Share this post Link to post Share on other sites
Racinbob 11,905 #40 Posted April 30, 2020 Considering the fact that so many of these transmissions have run for years on a milky mixture of water and oil they really aren't too particular as to what's in them. For me, as I've done for decades, it's 80w90 with 1 1/2 quarts in the 3 and 4 speeds and 2 quarts in the 6 and 8 speeds. Done deal. 2 Share this post Link to post Share on other sites
quahog 14 #41 Posted April 30, 2020 These diffs/ trans do not really run hot, IMO. I sellected Red Line MTL as it was on my shelf. It is a GL4 safe for bronze brass etc. Since I have never opened one of these up, I have no idea what the material make up is. Thanks for all the imput .. quahog 1 Share this post Link to post Share on other sites
Lee1977 7,160 #42 Posted May 4, 2020 On 4/30/2020 at 10:15 AM, quahog said: These diffs/ trans do not really run hot, IMO. I sellected Red Line MTL as it was on my shelf. It is a GL4 safe for bronze brass etc. Since I have never opened one of these up, I have no idea what the material make up is. Thanks for all the imput .. quahog There is not any bronze or brass bushing in an two piece 4 speed or 8 speed; It's needle bearings, ball bearings and roller bearings. Share this post Link to post Share on other sites
