dodge78 94 #1 Posted April 23, 2009 I will be installing new bolts because I only got one with the engine. First one is an original, I believe. The second one is longer but will fit the hole while the unthreaded part is shorter. The third one has a longer unthreaded part and will need more threads and cut to length. Both of the new bolts are not quite the same diameter as the old one. Which one would be the best to use? Share this post Link to post Share on other sites
catman81056 3 #2 Posted April 24, 2009 Try looking at the Kohler site and see if they sell bolt kits. Share this post Link to post Share on other sites
Prater 77 #3 Posted April 24, 2009 Are the bolts the same strength? If the bolt is not the same or better grade the head will warp or pop right off the engine. Look at the ead of the bolt for grading. http://www.boltdepot.com/fastener-informat...rade-Chart.aspx Share this post Link to post Share on other sites
dodge78 94 #4 Posted April 24, 2009 Are the bolts the same strength? If the bolt is not the same or better grade the head will warp or pop right off the engine. Look at the ead of the bolt for grading. http://www.boltdepot.com/fastener-informat...rade-Chart.aspx If I go off of the chart, its a grade 2 bolt and its 1 1/4" long. On the kohler site the bolts are 1 1/2" long. Share this post Link to post Share on other sites
dodge78 94 #5 Posted April 24, 2009 According to the yahoo group, Kohler Engine Club, they should be grade 8 with grade 8 flat washers at 1 1/2" long. Share this post Link to post Share on other sites
Prater 77 #6 Posted April 25, 2009 Go with the grade 8 bolts that are supposed to be on the head. You can get them at Lowes, HD, or ACE Hardware. Share this post Link to post Share on other sites
catman81056 3 #7 Posted April 25, 2009 What Prater said Grade 2 bolts should only be used for fishing sinkers, they break real easy. Share this post Link to post Share on other sites
