Countdown To Christmas!
noe
my 875
noe
My 875 starts but when I put the belt on it won't start.  the belt doesn't seem to be tight. when nothing on the pully it starts right up
ZXT
Will it attempt to crank? What belt are you speaking of? The drive belt or the PTO? Whichever it is, make sure that it turns freely.
noe
drive belt complete off starts no problem
ZXT
Can you turn the transmission pulley by hand?
Is this a tractor that you've had and used for a while or one you just got?
noe
one I just got. new carb. belt 71 in. they say it should be 72
kasey54
Does it turn over and fail to fire, or don't even try?
rmaynard
There is nothing on an 875 that would prevent the engine from starting with the belt on or off. In other words, no safety switches. With the belt on and the parking brake engaged, the belt is loose on the pulleys. When the parking brake is released, the belt tightens but is not super tight, just enough tension to turn the pulley on the transmission. There is nothing in the belt area that would effect starting. The only thing I can think of is the battery ground wire on mine connects to the bolt that holds the belt cover to the engine. I'd look there first.
Edited by rmaynard
