Tractorhead 9,216 #1 Posted December 13, 2019 Hi, i need the gros weight of an 3 Gear Gearbox complete incl. Pulley and wheelhubs, but without Oil. in Kilos or Lbs. thanks for Answer. Share this post Link to post Share on other sites
ebinmaine 77,518 #2 Posted December 13, 2019 Steve if you're talkin about a regular old wheel Horse manual gearbox I can get you a weight in a couple hours 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #3 Posted December 13, 2019 (edited) Great buddy thanks. i thinkin to buy maybe on big show a Gearbox for a Project i planed😎 i have 30Kilos free of charge, maybe it will be heavier i guess but how much is interesting. to calculate if it‘s worth to take it with me or maybe cheaper to send. Edited December 13, 2019 by Tractorhead 1 Share this post Link to post Share on other sites
ebinmaine 77,518 #4 Posted December 13, 2019 This is a mid 60s 3 speed. Should weigh the same as a later model 4 speed. My scale reads 88 pounds, (mostly drained). So about 39 to 40 kg I think... 6 and 8 speeds will be a touch heavier because of longer axles and an extra gear/lever set up. 2 1 Share this post Link to post Share on other sites
Tractorhead 9,216 #5 Posted December 13, 2019 (edited) Thanks buddy i appreciate your help. oh, was this my Gearbox.. Edited December 13, 2019 by Tractorhead 1 Share this post Link to post Share on other sites
Herder 2,355 #6 Posted December 14, 2019 1 hour ago, ebinmaine said: This is a mid 60s 3 speed. Should weigh the same as a later model 4 speed. My scale reads 88 pounds, (mostly drained). So about 39 to 40 kg I think... 6 and 8 speeds will be a touch heavier because of longer axles and an extra gear/lever set up. I bet you picked that up with one hand. 2 Share this post Link to post Share on other sites
ebinmaine 77,518 #7 Posted December 14, 2019 26 minutes ago, Herder said: I bet you picked that up with one hand. Might've.... 1 Share this post Link to post Share on other sites
Pullstart 68,944 #8 Posted December 30, 2019 Stefan... I bet with your carry on luggage you might be able to split it up! Most of us folks have tools for quick field stripping a wheel Horse at the big show! 1 1 Share this post Link to post Share on other sites
ebinmaine 77,518 #9 Posted December 30, 2019 5 minutes ago, pullstart said: Stefan... I bet with your carry on luggage you might be able to split it up! Most of us folks have tools for quick field stripping a wheel Horse at the big show! A gear here. A shaft there. A hub or 2 over yonder..... Share this post Link to post Share on other sites
