Countdown To Christmas!
seven
877 kills but then starts
seven
I have a buddy that has a 877 wheel horse and I did some work on it last summer I put a new head gasket in a new carburetor on it. And it ran fine during the warmer weather but he says it it kills on him when he's plowing snow but then it will start right back up again and run fine? This is happened to three times? Any suggestions
rmaynard
My guess is a clogged vent on the gas cap.
seven
 It wants to kill more when under load also?
ZXT
Could it be an ignition issue, since the issue appears to happen when pushing snow? If the points are getting wet maybe it's shorting the ignition out. Just a thought!
The Tuul Crib
 Especially it's a little gasket is worn out or gone on the points cover
peter lena
makes me think  its a wire chafe due to a frame flex electrical short , being an older and simpler unit , the wire issue is much easier than newer models. i would go over every connection , verify no corrosion and full wire to contact  point. the snow plowing is your lead in to the problem, pete
