truckin88 104 #1 Posted April 23, 2009 I recently picked up a clean 244-H, with the onan power plus 14 OHV and it is vertical. On the frame it has an (attach a matic) logo, does this tractor accept the same attachments as the standard C, 300, 400, because I have a feeling it does not, just wan to clarify, what kind of attachments can I get for it. Share this post Link to post Share on other sites
wh500special 2,281 #2 Posted April 23, 2009 No, it won't take the attachments from the bigger C/300/400/500 tractors. Both the hitch points and the PTO pulley are diffent on this tractor from the other WH's. Take your model number from the serial tag to toro's website and use the "look up parts" function. You will find a listing for compatible implements. Although I think 240 series implements are largely unique to that series, I think the snowthrower from the newer 260 series is a direct fit. And the snowblade from the smaller 200 series might fit as well. Steve Share this post Link to post Share on other sites
truckin88 104 #3 Posted April 24, 2009 would the plow off of 200 series fit?????? Anyone know? Share this post Link to post Share on other sites
