whtractors24 Â Â 3,453 #1 Posted December 6, 2019 7 9 1 Share this post Link to post Share on other sites
Pullstart   68,878 #3 Posted December 6, 2019 My two favorite round hoods. 3 6 1 Share this post Link to post Share on other sites
Lee1977   7,551 #5 Posted December 6, 2019  C-120/180-8 , 312-8 ,     5 1 Share this post Link to post Share on other sites
rjg854   12,841 #7 Posted December 6, 2019 16 automatic, the business end 4 1 1 1 1 Share this post Link to post Share on other sites
SylvanLakeWH Â Â 30,587 #8 Posted December 6, 2019 6 Share this post Link to post Share on other sites
953 nut   64,108 #9 Posted December 7, 2019 6 2 1 2 Share this post Link to post Share on other sites
Lee1977   7,551 #10 Posted December 7, 2019 8 hours ago, whtractors24 said: What are you planting in an asphalt drive way.  The only thing I know that will grow in asphalt is cane. My boss had cane growing up trough his neighbor asphalt drive. Share this post Link to post Share on other sites
The Tuul Crib   7,340 #11 Posted December 7, 2019 My 1067 414-8 and 855 7 1 Share this post Link to post Share on other sites
McGrew   461 #12 Posted December 7, 2019 One more for Friday:  6 1 Share this post Link to post Share on other sites
D_Mac   9,333 #13 Posted May 15, 2020 Its FRONT END FRIDAY FOLKS....... 2 1 Share this post Link to post Share on other sites
WHNJ701 Â Â 4,169 #14 Posted May 15, 2020 I' m in, test fit the new stack 3 4 Share this post Link to post Share on other sites
SylvanLakeWH Â Â 30,587 #15 Posted May 15, 2020 3 1 Share this post Link to post Share on other sites
Pullstart   68,878 #17 Posted May 16, 2020 Here’s a few... 2 3 Share this post Link to post Share on other sites
Flat Thunder Channel   178 #19 Posted May 16, 2020 3 hours ago, pullstart said: Here’s a few...   Why the lift??? It makes me paranoid it is going to fall. I dropped my lathe two year ago when a strap broke! Ever since that I have been paranoid about using straps .  Have you ever seen Handy brand lift tables? They are a popular American made lift table. I bought one for the harley's but it serves double duty for mower repair too.    1 Share this post Link to post Share on other sites
Tractorhead   9,216 #20 Posted May 16, 2020 @Flat Thunder Channel sadly bad luck if a Strap rip up or is underdimensioned. I ain’t be paranoid on a Lift at all.  But to have a Lathe on a Strap lift, i think would be more paranoid even if use just a 5 Times oversized Straps.  It’s depending on the Weight on the goods and the situation and the things you have to lift with, if the goods are sensitive like a Lathe i would take at least a 20 times safety on Straps or even better using chains.    1 Share this post Link to post Share on other sites
Pullstart   68,878 #21 Posted May 16, 2020 5 hours ago, Flat Thunder Channel said:  Why the lift??? It makes me paranoid it is going to fall. I dropped my lathe two year ago when a strap broke! Ever since that I have been paranoid about using straps .  Have you ever seen Handy brand lift tables? They are a popular American made lift table. I bought one for the harley's but it serves double duty for mower repair too.    it’s an old picture...  but I had just purchased that one and used it to build Frank, my wife’s custom tractor.  Normally I use the hilo to unload but can’t tell why I used he hoist that day.  Made for a good picture moment!   2 2 Share this post Link to post Share on other sites
Flat Thunder Channel   178 #22 Posted May 19, 2020 On 5/16/2020 at 3:49 AM, Tractorhead said: @Flat Thunder Channel sadly bad luck if a Strap rip up or is underdimensioned. I ain’t be paranoid on a Lift at all.  But to have a Lathe on a Strap lift, i think would be more paranoid even if use just a 5 Times oversized Straps.  It’s depending on the Weight on the goods and the situation and the things you have to lift with, if the goods are sensitive like a Lathe i would take at least a 20 times safety on Straps or even better using chains.   My lathe is a baby 12x36 Atlas. It is difficult to place chains on it in a safe fashion. During the incident I used 3 new ratchet straps. Unfortunately the extras only slowed it down because of its awkward load center. Once one broke it was all she wrote. One strap far exceeded the weight capacity of the whole lathe by 1.5 - 2 times. It only takes one sharp edge and the straps lifting days are over. Now, I'm pro chain for overhead lifting. Might use a strap to adjust load angle, but try to lean towards chain or cable on everything else.  1 Share this post Link to post Share on other sites
Tractorhead   9,216 #23 Posted May 19, 2020 1 hour ago, Flat Thunder Channel said: On 5/16/2020 at 9:49 AM, Tractorhead said: @Flat Thunder Channel sadly bad luck if a Strap rip up or is underdimensioned. I ain’t be paranoid on a Lift at all.  But to have a Lathe on a Strap lift, i think would be more paranoid even if use just a 5 Times oversized Straps.  It’s depending on the Weight on the goods and the situation and the things you have to lift with, if the goods are sensitive like a Lathe i would take at least a 20 times safety on Straps or even better using chains.   My lathe is a baby 12x36 Atlas. It is difficult to place chains on it in a safe fashion. During the incident I used 3 new ratchet straps. Unfortunately the extras only slowed it down because of its awkward load center. Once one broke it was all she wrote. One strap far exceeded the weight capacity of the whole lathe by 1.5 - 2 times. It only takes one sharp edge and the straps lifting days are over. Now, I'm pro chain for overhead lifting. Might use a strap to adjust load angle, but try to lean towards chain or cable on everything else.    Ouch, that hurts.  So you learned the Hard way.. Hope the machine didn‘t damaged at all.  was it a Model 3983 ?  Share this post Link to post Share on other sites
Flat Thunder Channel   178 #24 Posted May 20, 2020 Is it bad I forgot the model? I think it is a 3996. The fall broke my quick change gear box handles at the quick detent knob. I since bought two different headstock units for spare parts. Thinking about making some cool accessory with the extra parts. Share this post Link to post Share on other sites
Flat Thunder Channel   178 #25 Posted May 22, 2020 I just checked I was off a digit it is a 3986. I used it to repair the u-joint coupling on my 843 Bobcat. You can see it working on video #2. I am no machinist, but I can make chips on a good day ;).   2 Share this post Link to post Share on other sites
