stevebo-(Moderator) 8,534 #1 Posted December 2, 2019 I got this weight with a 312 I recently acquired. Not sure if oem or where it goes? Any info or pictures would be appreciated. Share this post Link to post Share on other sites
ebinmaine 72,740 #2 Posted December 2, 2019 That's an interesting piece Steve. Do those carriage bolts square holes line up with four holes on the frame or maybe on an implement you might have? Share this post Link to post Share on other sites
82Caddy 851 #3 Posted December 2, 2019 There is a pair on ebay right now listed as frame weights. I've been keeping an eye on them but can't find much info. Share this post Link to post Share on other sites
Mikey the Monkey 700 #4 Posted December 2, 2019 the manual is also available, explains what it was for...lawn ranger rear weight..bolts to tractor under the seat Share this post Link to post Share on other sites
JCM 10,226 #5 Posted December 2, 2019 Almost looks like a section of a steel concrete filled lally column with flat stock welded to it and painted WH red ? What is the diameter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,492 #6 Posted December 2, 2019 There was a front frame weight for the 600-Series of early zero-turn tractors. The parts list shows four 3/8-16 x 1-3/4 carriage bolts and four 3/8-16 Nylok nuts. There are also two 7/16-14 x 5" carriage bolts so may not be the one in question. There is no illustration. https://www.partstree.com/models/81127-toro-front-weight-kit-for-zero-radius-tractor/600-series-front-weight-kit-8-1127-0/ Garry Share this post Link to post Share on other sites
Sparky-(Admin) 23,168 #7 Posted December 2, 2019 How or where was it mounted on the 312? Or was it separate? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,534 #8 Posted December 3, 2019 It was separate from the machine. I thought it might mount to the rear tach o matic but does not line up. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,534 #9 Posted December 3, 2019 Gary, looks like that Weight is still available for 256 bucks!! Share this post Link to post Share on other sites
