mcurran 37 #1 Posted December 1, 2019 Can anyone tell me if a mower deck from a 1972 Raider will fit on a C81. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #2 Posted December 2, 2019 Was hoping someone with experience would reply. You can likely make it work but not worth it in my opinion. The drive is completely different and the older decks use blades with a 5/8" x 3/4" double-D center hole that are hard to find if not impossible. Using an older attachment on a newer tractor is not taking advantage of improvements made over time. There should a lot more decks available that are newer than your tractor than older ones. Even the last decks produced after tractor production ended will plug and play on a C-81 and if you get one using blades with a 3/4" center hole parts should never be a problem. If you post the size and style of deck you want we can give you a list of good candidates. Garry 1 Share this post Link to post Share on other sites
Stepney 2,354 #3 Posted December 2, 2019 If the deck is original, then yes it 'can' work. You won't be able to use the C's original lift arm, you'll need a chain from the rock shaft to the mower lift tab. Other then that, it'll still mount up and function. The mule drive will work just as it would on a newer model deck. If your trying to use the original old style belt rigging though, I don't think that is possible. The front driven unit is better anyway, IMHO. Share this post Link to post Share on other sites
