richmondred01 2,311 #1 Posted November 30, 2019 Going to install FACET POSI-FLO FUEL PUMP Im tossed up as to which one the 1-2PSI or 1.5-4PSI. I’ve used the 1-2 psi in Kohlers with good success. However, the onan is a different animal. What do you guys use? thanks. Share this post Link to post Share on other sites
Kurt-NEPA 755 #2 Posted November 30, 2019 I've been using an Airtex E8016S electric fuel pump on both of my 520H's. They have been flawless. They are 2.5 - 4.5 psi pumps. I'm not sure I need that much pressure. Hope that information helps. Share this post Link to post Share on other sites
WildmanC120 613 #3 Posted December 1, 2019 I'm using a Holley look alike version of the facet on my P216. I don't remember the pressure. It's been fine for a few hours now. Just make sure you remove the manual pump as to not pump fuel into the crankcase. Share this post Link to post Share on other sites
richmondred01 2,311 #4 Posted December 1, 2019 Going with the 1.5-4PSI. 1 Share this post Link to post Share on other sites
