WVHillbilly520H 10,378 #26 Posted December 1, 2019 The anniversary 520 with cab and deuce I bought brand new and the other 520 with blade I bought used is older with less hours. And of course the Kioti for use in WV. Then if I ever find time to convert these orange implements over to my lil red diesel 8 4 Share this post Link to post Share on other sites
12Horse Paladin 1,038 #27 Posted December 1, 2019 2 hours ago, Digger 66 said: Sorry guys , no attachments for the Wheel Horse . Only the poly dump cart . All I have is this semi-restored and re-powered '66 tank . 👍👍👍 I dont have any WH setup for snow...yet😉 Hoping next winter my newly acquired Bronco 14 is, with plow😊... Like You. These are mine, as firedup today in prepaeation. Guessin maybe that's tomorrow morn, if what is being predicted holds. Both '73s; the Tralblazer ready to go this 1st year with me, mid-resto. Both Techys; 7 & 8HP, respectively. 9 Share this post Link to post Share on other sites
cschannuth 3,821 #28 Posted December 1, 2019 (edited) Last winter... IMG_5963.mov Edited December 1, 2019 by cschannuth Forgot one. 5 10 Share this post Link to post Share on other sites
ebinmaine 78,126 #29 Posted December 1, 2019 Got the bracket changed out from the tow hitch and mounted the plow today. Should be ready for the upcoming blast-o-winter. 8 3 Share this post Link to post Share on other sites
ZXT 2,401 #30 Posted December 1, 2019 10 minutes ago, ebinmaine said: Got the bracket changed out from the tow hitch and mounted the plow today. Should be ready for the upcoming blast-o-winter. Are those 6" fronts? Looks like a lot of rubber. Share this post Link to post Share on other sites
ebinmaine 78,126 #31 Posted December 1, 2019 7 minutes ago, ZXT said: Are those 6" fronts? Looks like a lot of rubber. Oh no no no.... This picture actually makes them look kind of small. They are 20 x 8 x 8 tires that are fluid-filled for extra weight. 4 inches taller than stock of course but I don't care about the extra 2 inch rise of frame height because I have no mower decks. If anything, it helps quite a lot with ground clearance while plowing and driving in our rough woods. 2 Share this post Link to post Share on other sites
pfrederi 20,195 #32 Posted December 1, 2019 Just now, ebinmaine said: Oh no no no.... This picture actually makes them look kind of small. They are 20 x 8 x 8 tires that are fluid-filled for extra weight. 4 inches taller than stock of course but I don't care about the extra 2 inch rise of frame height because I have no mower decks. If anything, it helps quite a lot with ground clearance while plowing and driving in our rough woods. Is the horn to warn the local Moose's while you are plowing??? 1 4 Share this post Link to post Share on other sites
ebinmaine 78,126 #33 Posted December 1, 2019 3 minutes ago, pfrederi said: Is the horn to warn the local Moose's while you are plowing??? Of course it is. You can't have a moose in your way when you're plowing. That's actually the ah-oooogaa horn I put on for Owls Head last year. I took it off today, for the winter. 2 Share this post Link to post Share on other sites
Tach-a-matic 357 #34 Posted December 1, 2019 B-80. Without a doubt the easiest machine to work on ever. Only two safeties, fuel tank is easily accessible/removable, minimal levers and rods, and everything is out in the open its so refreshing S16H. still easy (compared to a car) but nothing like a mid 70's Horse 7 3 Share this post Link to post Share on other sites
ebinmaine 78,126 #35 Posted December 2, 2019 15 minutes ago, Tach-a-matic said: B-80. Without a doubt the easiest machine to work on ever Agreed. Those B and C series are awesome... 1 1 Share this post Link to post Share on other sites
pfrederi 20,195 #36 Posted December 2, 2019 Still snowing a bit so I will wait for tomorrow to plow down to the barn. #1 Plow Charger 12 6 6 Share this post Link to post Share on other sites
Lane Ranger 11,933 #37 Posted December 3, 2019 4 hours ago, pfrederi said: Still snowing a bit so I will wait for tomorrow to plow down to the barn. #1 Plow Charger 12 Boy you sure have a "test load" in Pennsylvania Paul! Stay warm and safe! 1 Share this post Link to post Share on other sites
WHX?? 55,954 #38 Posted December 3, 2019 (edited) Hope you guys don't mind some more action shots. 520 with a single in 14" of fresh powder day before turkey day in northern WI deer camp. Busting the initial trail through 2 ft drifts in 30 mph winds was the worst. Got a real quick lesson on keeping the chute turned with the wind! Doing good till I lost the pin that holds the attach keeper up into the front attach. A tie down lashed the blower back to the tractor and ran a 1/4 mile backwards in my own tracks to camp for repairs. Luckily I found the bracket in the snow and a piece of all 3/8 all thead for a new pin and back in business. Finished clearing a 1/2 mile of road plus parking areas. Four hours of seat time not counting down time for repairs. 6 gallons of gas. Guys are right about needing to keep a single loaded up. Onan never missed a beat other than being thirsty. Edited December 3, 2019 by WHX24 10 12 Share this post Link to post Share on other sites
12Horse Paladin 1,038 #39 Posted December 3, 2019 8 hours ago, WHX24 said: Hope you guys don't mind some more action shots. 520 with a single in 14" of fresh powder day before turkey day in northern WI deer camp. Busting the initial trail through 2 ft drifts in 30 mph winds was the worst. Got a real quick lesson on keeping the chute turned with the wind! Doing good till I lost the pin that holds the attach keeper up into the front attach. A tie down lashed the blower back to the tractor and ran a 1/4 mile backwards in my own tracks to camp for repairs. Luckily I found the bracket in the snow and a piece of all 3/8 all thead for a new pin and back in business. Finished clearing a 1/2 mile of road plus parking areas. Four hours of seat time not counting down time for repairs. 6 gallons of gas. Northern WI, eh? Wherebouts? My folks live in Marinette😊 Hope you got the Big One; most i know werent very lucky this yr... 1 Share this post Link to post Share on other sites
The Tuul Crib 7,353 #40 Posted December 3, 2019 Of course here in the mid south we don't get a whole lot of snow but when we do I will be ready ! 9 5 1 Share this post Link to post Share on other sites
WHX?? 55,954 #41 Posted December 3, 2019 (edited) 36 minutes ago, 12Horse Paladin said: Northern WI, eh? Wherebouts? Eagle River/Conover area... we are about 10 miles south of the UP. Can always push the dirt & gravel with those Cribs... Edited December 3, 2019 by WHX24 1 Share this post Link to post Share on other sites
WHX?? 55,954 #42 Posted December 3, 2019 Of course I'd be remiss if I didn't post this annual pic here... my favorite sno mover...the missus with a shovel! 3 1 5 Share this post Link to post Share on other sites
JCM 11,075 #43 Posted December 3, 2019 Nice to have someone who doesn't mind using a shovel to help with the cleanup.Beautiful garage you have there, looks like a Morton building. Keep on bringing the 520-H snow removal pics. Never have used a Single stage, seems to do a nice job. 1 Share this post Link to post Share on other sites
Blackhood Bill 728 #44 Posted December 3, 2019 (edited) This is from last year. C-145 with single stage blower, no problems with clogging up! Nothing here as of yet Edited December 3, 2019 by Blackhood Bill 4 4 Share this post Link to post Share on other sites
WildmanC120 613 #45 Posted December 3, 2019 I'll have some pics and video later today of my 416H running a 41" single stage. We got hammered here over the last 2 days and I have not been home to VT yet. Been staying at my girlfriend's house which is closer to my work in NY. I'm leaving work soon (sick time cough cough) so I can go play. I'm hoping the 416 and single stage will handle it. I'm currently trying to button up my install of the 2 stage on my 161 but the snow came early. We will see I guess. This is a photo from my cameras I have setup at the house. I'm driving my Tahoe but as you can see my car is pretty buried. 8 Share this post Link to post Share on other sites
ebinmaine 78,126 #46 Posted December 3, 2019 Portland Maine (work terminal) should end up with 6 or 8 inches. At home Trina says only a couple inches fell. Only about 30 miles difference. I'll get a chance to play with the Cinnamon Horse later today. 1 Share this post Link to post Share on other sites
Super-C 4 me 612 #47 Posted December 3, 2019 (edited) About 2 weeks ago I added some extra weights to my plow rig IMG_4685.3gp Edited December 3, 2019 by Super-C 4 me 3 9 Share this post Link to post Share on other sites
WHX?? 55,954 #48 Posted December 3, 2019 (edited) 3 hours ago, JCM said: Beautiful garage you have there, looks like a Morton building. Actually no Jim but it does look like one. Regular stick build with common trusses. Back in '87 when I built it T-111 was all the rage in siding so that's what I used . Trouble was the siding had defects where missed material made horizontal strips in-between the vertical grooves. Bugs got in the horizontal strips then the woodpeckers went after the bugs & sometimes put a hole right through it. Louisiana Pacific the maker had to cough up some coin so say the lawyers but I never got any! Couple years back I got tired of looking at it and staining all the time so just put steel on and was done with it. Yes this single surprised me on how far it launched it. They don't do well with light dustings tho.. 2 or less inches. You have to run in 3rd or as fast as the hydro will push to keep it loaded up. My short chute doesn't do nearly as well. Fact last year the short got ripped right off in slush and ain't gonna get fixed --- look for a long chute and convert it. Edited December 3, 2019 by WHX24 4 1 Share this post Link to post Share on other sites
Burnerman 759 #49 Posted December 3, 2019 Learned a few things. Solid link on the plow= awesome for the icy crust from this storm. Chains and turf tires = awesome. I’ve had the chains on the AGs and they stink. The biggest thing I missed was the fun I had pushing snow on it!!😁 Oh! And these monkey grip gloves are the best thing going for hands on snow removal. Hands warm and dry and they might save a finger from a snowblower. 😲 don’t ask how I know. 8 4 1 Share this post Link to post Share on other sites
ebinmaine 78,126 #50 Posted December 4, 2019 Well we had another HUGE milestone here today. Trina was home from work and we got about 4 inches of snow. She hopped on her 867 "pigpen" or "otha tracta" and moved some-o-the white stuff..... With the mid mount grader!!! Unfortunately I don't have pics of that because I wasn't home. But!!! She's decided to have us set up that tractor with a 42" snow plow! So we'll be trying out a new thing for her then as well... We'll keep ya posted. Here's a video of me on the Cinnamon Horse she took from the porch as I was cleaning up. 5 2 Share this post Link to post Share on other sites
