AHS 1,546 #1 Posted November 29, 2019 Ok I am putting together for the first time (snowblower came in a box!) and I want to have an exploded parts diagram... I have new bearings, and I want to make sure I have all the washers and spacers in place! I looked in the wheel horse implements and attachments for a 79360 and I found some but no exploded parts diagram... any one except me can find it!😳 Share this post Link to post Share on other sites
AHS 1,546 #2 Posted November 29, 2019 I got the parts diagram from my old wheel horse dealer! Score! Who new they were going to be open on Black Friday! 👍😄 Share this post Link to post Share on other sites
peter lena 9,281 #3 Posted November 29, 2019 AHS, LUCKY YOU! JUST THE IDEA OF SETTING UP A NEW UNIT , INSTEAD OF YSED JUNK , WOULD BE A REAL TREAT . I WOULD RECOMMEND DETAIL LUBING ALL MOVEMENT AND FRICTION POINTS . THE BELT PULLEY FRAME BEHIND THE BLOWER AND IN FRONT OF THE FRONT LOWER HOOD , AREA , IS OFTEN NEGLECTED , IF THE SPRING TENSION AND BELT TENSION , CAN EASILY MOVE THE PULLEY FRAME , IT WILL SPIN UP EASIER AND QUICKER. ALSO USE CABLE AND CHAIN LUBE ON THE AUGER CHAIN DRIVE . I REGULARLY LUBE MINE FOR BEST OPERATION. LUBE THE SNOW CHUTE RELATED MOVEMENT AREAS , I PUT MY BLOWER ON A 4X4 TO MAKE HOOKING IT UP EASIER, AT THE FRONT TECHAMATIC . DON,T USE IT AS A BATTERING RAM , LEARN FROM ALL YOUR USE , JUST A FEW TIPS , GOOD LUCK WITH IT , PETE Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,499 #4 Posted November 29, 2019 The OM IPL in the file title are operator manuals and illustrated parts lists. https://www.wheelhorseforum.com/search/?q=79360&type=downloads_file Garry Share this post Link to post Share on other sites
