Mudrig150 376 #1 Posted November 18, 2019 (edited) What would be the best electric fuel pump to put on a tractor with a Magnum 18, where the tank is lower than the carb? I don't really want to use the stock fuel pump, mainly to spare my starter. Edited November 18, 2019 by Mudrig150 Share this post Link to post Share on other sites
pfrederi 19,883 #2 Posted November 18, 2019 I have used Facet Powerflo on 3 tractors some for several years now no issues,. I use teh 1.5-4 psi 60245 others my prefer lower psi 60304 Made in USA I tried one of the cheapy chicom knock offs it died after only a few hours run time ...a long way from the shop. I know other had better luck with them You pays your money you take your chance.... https://www.aircraftspruce.com/catalog/eppages/solidstatepump.php 1 1 Share this post Link to post Share on other sites
Mudrig150 376 #3 Posted November 18, 2019 4 minutes ago, pfrederi said: I have used Facet Powerflo on 3 tractors some for several years now no issues,. I use teh 1.5-4 psi 60245 others my prefer lower psi 60304 Made in USA I tried one of the cheapy chicom knock offs it died after only a few hours run time ...a long way from the shop. I know other had better luck with them You pays your money you take your chance.... https://www.aircraftspruce.com/catalog/eppages/solidstatepump.php What size are the fittings? Share this post Link to post Share on other sites
pfrederi 19,883 #4 Posted November 18, 2019 27 minutes ago, Mudrig150 said: What size are the fittings? Scroll down the page I linked it shows that stuff way down. Share this post Link to post Share on other sites
Mudrig150 376 #5 Posted November 18, 2019 1/8" NPT, but for 5/16" fuel line. Share this post Link to post Share on other sites
pfrederi 19,883 #6 Posted November 18, 2019 (edited) The model i use comes with two 1/8 npt with 1/4" barbs. I use 1/4" fuel line on all the WHs. (now using the yellow stuff) You can buy 1/8npt with 5/16 barb fitting if you really want to use 5/16 line Edited November 18, 2019 by pfrederi 1 Share this post Link to post Share on other sites
Mudrig150 376 #7 Posted November 18, 2019 4 minutes ago, pfrederi said: The model i use comes with two 1/8 npt with 1/4" barbs. I use 1/4" fuel line on all the WHs. (now using the yellow stuff) You can buy 1/8npt with 5/16 barb fitting if you really want to use 5/16 line Mine has 1/4" line, too. 1 Share this post Link to post Share on other sites
